850 leg room (lack of)?
Old Sep 27, 2010 | 04:34 PM
Jim-Mer's Avatar
Default 850 leg room (lack of)?
My wife has a 96 850 and I have a 05 S60. She is on the verge of exercising imminent domain over my S60, and I'll wind up with the 850. Which is cool I don't drive that far to work. Problem is there is no leg room in the 850. With the seat all the way back it measures 20" from the front of the seat to the center fo the brake pedal. Is there an "alternative" mounting positon for seats? I looked under the seat where the rails are mounted and don't see anything. The PO was a wee little fellow and he probably needed help...but I'm 6'2" and need the room. Can someone tell me if this (20") is all there is?
Thanks,
Jim
Old Sep 27, 2010 | 05:02 PM
TheTrainwreck's Avatar
Damn are you 7' or something? I'm 6'4" and I got my seat set up nicely. Try messing with the tilt. It should feel like you're in a fighter jet cockpit. At least that's what it's like for me
Old Sep 27, 2010 | 11:50 PM
gdog's Avatar
Wow, that's really strange!!
We test drove a S60 before and decided against it; one of the major reasons was absolutely NO rear leg room!!
Old Sep 27, 2010 | 11:59 PM
91shelby's Avatar
im 6' 1" and i have mine setup nicely and have ample leg room, though my 960 has more leg room bit is also longer than my 850 wagon...
Old Sep 28, 2010 | 06:44 AM
S70driver's Avatar
Yeah there should be plenty of leg room in the 850 for you.
Old Sep 28, 2010 | 09:30 AM
matt01's Avatar
i think he means front leg room.
Old Sep 29, 2010 | 07:02 AM
Jim-Mer's Avatar
Correct, front leg room. My S60 has plenty, my 850 has little. Can someone check the 20" measurement from the front of the seat cushion to the brake pedal please? Is there an alternative mounting position for the seat rails?
Jim
Old Sep 29, 2010 | 07:10 AM
ibified's Avatar
I almost wonder if your seat is not going all the way back for some reason. I'm also 6'2 and i have NO problem with legroom.
Old Sep 29, 2010 | 09:30 AM
matt01's Avatar
ive had the seat completly out of my car.. no theres no alternative way.
Old Sep 29, 2010 | 10:44 AM
boxpin's Avatar
Maybe a measurement should be made from the front of the seat (moved all the way back) to the firewall.
Old Sep 29, 2010 | 09:29 PM
Jim-Mer's Avatar
That was my logic measuring from the front of the seat bottom to the brake pedal...that or firewall either one would at least give me a reference point.
Maybe it isn't going all the way back...again, a reference measurement would help.
Jim
Old Oct 1, 2010 | 10:49 PM
gdog's Avatar
Sorry; i mis-read your initial post...
I get 21" from the center of the brake pedal to front of seat with slider all the way back. Adjusting the tilt from there gives +/- about 0.5" delta or so from that measurement.
You might be able to notch the mounting holes a bit but that would not give you much more. Other than you're going to have fab something custom; seat mounts are safety related so can't half-*** it...
Old Oct 2, 2010 | 10:58 AM
I like to sit with my seat pretty far back but I'm only 5'-4". LOL, I thought you were never going to get a measurement from anyone.
I also have not seen any alternate mounting options for the seat. Maybe you can remove the front seat and drive from the back seat. LOL. Or maybe get rid of the thing & replace it with a 960 but I don't like how high the 960's ride.
If I see anything different later I'll post back.
Old Oct 3, 2010 | 04:21 PM
Jim-Mer's Avatar
I think my only option is to remove the seat and completely think through an alternative mounting scenario. Or, just pretend it is comfortable.
Jim
timfortin
Volvo C30
Apr 5, 2014 04:26 PM
keltickev
Mar 28, 2011 09:35 PM
RogerJohn
Penta
Jun 30, 2010 02:50 PM
VolvoDriver
Feb 17, 2007 02:35 AM
fignozzle
Nov 15, 2005 02:04 PM
