850 needs cat...what to do?
Old Aug 18, 2011 | 03:03 PM
AlanS's Avatar
Default 850 needs cat...what to do?
1995 850 NA wagon...I have a hole in the cat, on the top where it really can't be fixed. Two questions:
1. What's the best / most cost efficient way to replace this unit?
2. There's a brace/ plate that is over the cat area...two bolts on the pass side, two on the driver's side. Looks like it either protects the cat or offers structural support. Anywho... tried to unbolt it, the bolts spin out. The nuts are hidden between the floor panel and I can't figure out how to take this plate off...Should I just cut it off, eliminating it? You can't get the cat out without this plate being removed.
Old Aug 19, 2011 | 10:17 AM
MattyXXL's Avatar
The cheapest way, with out headaches is to go to a muffler shop and have them cut and weld one in. From what I have heard none of the ones from auto zone, discount, and pep boys dont fit properly. I have even heard of struggles with the ones from fcp.
As far as the cross member, after the 4 bolts are out sometimes you need to just wack it with a mallet. The years of road grime sometimes damn near weld it to the under carriage.
I pulled mine off after installing my exhaust and never put it back. The position of the bolts makes me think its not structural. its just a cross member if your exhaust brackets break off.
Old Aug 19, 2011 | 11:47 AM
boxpin's Avatar
I pulled mine as well, havent put it back in because of laziness. If you absolutely must take that plate off and the bolts are indeed spinning you will probably have to grind the heads off. I find it odd that they are spinning.
I have a cat if your interested. PM me.
Old Aug 23, 2011 | 11:52 AM
JimKW's Avatar
I tried three of them from FCP and none worked. I got one from Advance Auto and it didn't work. Finally I went to Monro Muffler and they cut the old on out and welded in a new one. It was also the cheapest option by a good bit too.
Old Aug 23, 2011 | 02:42 PM
My wife said if you need at CAT, don't get a DOG.
stevenro64
Apr 19, 2011 05:23 PM
cranky
Intake, Headers and Exhaust
Jan 22, 2006 03:39 PM
flamejet
Nov 29, 2005 10:21 PM
lyn 440glt
Jun 14, 2005 07:59 AM
tassadar30
Mar 17, 2004 01:39 AM
