850 no spark
850 no spark
Hello all and thanks for the add. I recently bought a 94 850 turbo. Had to replace starter. Was able to get it started for a few days, then nothing. Not getting spark. Tested crank sensor and it reads around 300 ohms. Replaced computer and coil. Coil reads 12 volts and drops to 11 when cranking. Could crank sensor be bad even though it test ok? Anything else I need to check. Please help. Thanks
