850 odometer not working
You may be able to retrieve actual mileage data using this procedure...
https://volvoforums.com/m_31489/tm.htm
There are plastic gears in there and most likely what causes it is resetting the trip odometer while you are rolling, They can't handle that. The part is $115 and about 3 hours labor to replace it. Quite a job!
The Gears can be bought online for Like 25.00 at this site.
http://www.odometergears.com/subpages/volvo.html
Mine broke aprox. at 126k. It's somewhat easy to replace it yourself, you just have to take the time to do it. Bought the gear from the dealer for $40 but saved lots of $ by doing it myself. It took me about 3 hours on a sat. morning. Be careful to plug again the pass. side airbag before turning the car on. That's one thing i forgot and ended up at the dealer to get it reset. Also if you decide to disconnect the battery when working on it, make sure you have the radio code.
janeofdrama
May 24, 2010 08:02 PM
