850 se central locking
Old Aug 3, 2009 | 04:54 AM
david59's Avatar
Default 850 se central locking
when I use key in drivers door central locking will not work on other doors. but if I use key in passengers door all the other doors including drivers door work ok.can somebody help with where to start looking for fault.eg, door handle key lock or latch unit? thank you
Old Aug 3, 2009 | 06:46 PM
Ozark Lee's Avatar
What year is your car and do you have a lock switch on the dash? The late '95 and on versions have a double locking system that only opens the driver's door unless you turn the key twice.
...Lee
Old Aug 3, 2009 | 07:09 PM
david59's Avatar
Lee it is a 1993 with no switch on dash.I have already removed drivers door trim.
Old Aug 4, 2009 | 11:18 PM
mhutchens's Avatar
I had similar trouble with the trunk lock on my 94 850. The document in the link details how to troubleshoot the central locking system and has a wiring diagram. My trunk lock turned out to have a bad actuator, a little luck an $8 at my local pull-a-part and the problem was solved.
With the wiring diagram the system is pretty easy to troubleshoot with a meter.
http://www.volvoclub.org.uk/tech/ser...ntrySystem.pdf
Old Aug 5, 2009 | 08:33 AM
david59's Avatar
mhutchens thankyou very much for the link. I will have a good read of documents and try to fix over the weekend.
Old Aug 5, 2009 | 09:12 AM
boxpin's Avatar
I had the same trouble with my rear hatch but the actuator was fine but did not have the Umph to push the latch all the way so the system would not lock. To solve it I added an aftermaket actuator in conjunction with the stock for extra Umph. No problems since.
jaddley
Apr 1, 2012 04:25 AM
guptash
Nov 19, 2011 04:17 PM
mtleiter
Feb 26, 2011 05:03 PM
giddingsw
Aug 11, 2005 02:00 PM
guptash
Feb 1, 2005 12:32 AM
