850 Stalling on turns (moved from 240/740/940)
Old Dec 18, 2013 | 11:50 PM
Lulumike's Avatar
Default 850 Stalling on turns (moved from 240/740/940)
Same with mine (1994 stick, 850) on tight turns up hill. The grade is not that bad but if I let my foot off the accelerator for any reason (say to downshift), it'll stall, especially if there's no much fuel left. There's also a gasoline smell. I wonder if it has anything to do with the fuel tank cap not closing tight enough? Once it stalled, I just down shifted to 2 and it caught and kept going. Another time, no downshifting helped. I just coasted until I put it in gear then it caught and took off. Sounds like a fuel problem, no?
Old Dec 20, 2013 | 07:52 PM
Lulumike's Avatar
Default stalls on tight uphill turns
When I stall on tight uphill turns, on all occasions, the fuel tank has been close to about 4 gallons. But once filled beyond that, especially nearly full, it has never happened. That suggests a gasoline pressure problem, which could be many things I suppose. Gas cap, fuel pump (it's new on mine), gas intake leak, maybe air intake leak as well. What do you think?
Old Dec 23, 2013 | 10:23 AM
fochs's Avatar
That suggests an in tank pump problem. Is your main pump loud?
Old Dec 24, 2013 | 09:14 PM
Lulumike's Avatar
Default gas cap etc
No, no noise. It's a new pump. And elsewhere, the engine responds very well.
Old Dec 24, 2013 | 10:11 PM
fochs's Avatar
I've only had stalling in my VW's, I'd check the in- tank pump operation soon because it will kill your main pump if it is out. Never had other symptoms operationally with a bad in- tank other than stalling on turns.
Old Dec 25, 2013 | 02:17 AM
my 92 740 turbo wagon had the in tank pump fail. That made the main pump noisy, and the car was glitchy below about 1/3rd tank... new in-tank filter and it was solid again.
Old Dec 25, 2013 | 04:32 PM
Lulumike's Avatar
Default gas cap etc
There's another pump in addition to the in-tank pump?
Old Dec 25, 2013 | 06:44 PM
yeah, Bosch LH fuel injection systems used on 240's and most 740/940's have dual pumps, the tank pump is just a booster, the main pump is under the car. Some 7/9's have regina injection, this only uses a single in-tank pump (which is a high pressure pump unlike the in-tank pump used with LH).
without the main pump, the engine flat won't run, there's no fuel pressure.
Old Jan 14, 2014 | 02:05 PM
ooof, I just browsed this thread again. Lulumike has a 850, that only has the single in-tank pump, and NONE of this is applicable, in fact, it belongs in the 850 forum, where I'm going to move it.
Old Jan 16, 2014 | 11:56 PM
gdog's Avatar
Who installed the pump? Wonder if they left off the pickup on bottom of pump.
Old Jan 17, 2014 | 12:18 AM
or if its anything like a 740/940 tank pump, its not easy to get the pump+level sender into the tank, and its WAY too easy to knock the pickup off when you're doing so.
Iggyomega
Apr 10, 2020 07:23 AM
Stb7
Nov 6, 2013 09:12 AM
gregmuseo
Apr 29, 2010 12:05 PM
deflecto
Nov 28, 2005 04:27 AM
