850 trans problem
850 trans problem
I have a 95 850 GLT auto trans. The trans will drive fine then the yellow arrow light comes on and the trans starts to slip, eventually no gears at all. This occurs over about a 2 to 3 mile distance. I check and clear the ODB codes and it runs fine again for about 2 to 3 miles. The code states wrong gear ratio (P0740?)
RE: 850 trans problem
Further, I neglected to mention the car has about 150,000 miles. I flushed the fluid due to water leaking into the trans via the radiator trans cooler. Radiator has been replaced. This problem started after I discovered the water leakage issue. Also the OBD code is P0730- gear ratio incorrect. (not P0740)
nortons
02-23-2015 12:14 AM
ded137t5r
06-10-2012 08:40 PM
Eric's Hot Rod Shop
07-14-2011 09:26 AM
