850 turbo plastic hose to intake manny
Old Oct 21, 2007 | 06:51 PM
Benihana's Avatar
Default 850 turbo plastic hose to intake manny
Hi guys. I was trying to replace all the vacuum hoses in my 850 turbo, and I accidently broke a plastic tube, and a small vacuum line, both covered with thick insulation. It goes from the the end of the intake tube(near the turbo inlet), and it attaches to the intake manny right behind the throttle body. It looks like a thick plastic,and now there is a vacuum leak on both broken ends. What is this part called, I need to order a new one, and I can't find what it exactly is.
Old Oct 22, 2007 | 12:39 AM
99VolvoV70's Avatar
Default RE: 850 turbo plastic hose to intake manny
Is it visible in this picture?: http://www.partsquick.com/ProductPic...&t=Diagram
Part numbers should be right for a '97 GLT, not sure what you are driving.
Old Oct 22, 2007 | 03:03 AM
Benihana's Avatar
its a 95 850 turbo. I think i found what it is. Its a hard line vacuum hose, I think its part of the PCV system.
Old Oct 22, 2007 | 04:20 AM
JPN's Avatar
JPN
I believe you should be able to find the plastic vacuum tube at:
http://www.fcpgroton.com/volvo850vacuumelbow.htm
http://www.fcpgroton.com/volvo850oiltrapturbo.htm
Welcome to the forum, and good luck to you,
JPN
Old Oct 22, 2007 | 04:43 PM
JimKW's Avatar
Wait I have an easier fix that Tech taught me when I did the same thing. Close off the fitting close to the thermostat on the intake manifold by capping it off. Then take one of the caps off the vacuum tree and run a line to place where the one you just capped off goes to. Mine has been running fine that way.
mark2765
Oct 10, 2012 05:31 AM
shwebo
Jan 30, 2012 09:00 PM
jg1
Aug 1, 2009 12:43 AM
halcyon419
Mar 30, 2009 02:15 AM
JimKW
Mar 29, 2009 08:53 AM
