850 Turbo Power Antenna
Old May 8, 2011 | 04:10 PM
budruss's Avatar
Default 850 Turbo Power Antenna
What stops the motor from running when the antenna reaches up or down position? I don't see any micro switches. Is it the box above the motor?More resistance trip the circuit?
Old May 8, 2011 | 10:09 PM
Either the strain on the motor or the motor timing out.
Old May 9, 2011 | 12:03 AM
gdog's Avatar
Senses the current draw of the motor and likely a max timer as well. Once the motor stalls (stops against a load) the current draw will spike.
Why do you ask; replacing the mast?
Old May 9, 2011 | 10:12 AM
budruss's Avatar
Yes, mast cord broken. Removed broken piece, re installed and motor kept running. Thought I would check here to see if someone here knew the system. I assumed it was the increased resistance, but didn't take the assembly totally apart, just the cover to remove broken cord. Thanks
Old May 9, 2011 | 10:41 AM
Did you install a new mass? Does it pull the antenna down and push it back up? How long does the motor run?
Old May 9, 2011 | 01:10 PM
budruss's Avatar
Ordered new oem mast($16.95 with shipping) on ebay. Not sure how long it would keep running, bu ran 40 seconds or so after running antenna up. I think the extra length of new unbroken cord will stop it. I think it ran off the cord as I can freely pull it up and down by hand.
Old May 9, 2011 | 08:32 PM
Yea, something is not right. Get your stuff like that from FCP or iPD. I think you have a bad one. You should not be able to pull it up or down by hand because when the radio is off it goes down and you cant grab it.
Old May 9, 2011 | 10:15 PM
budruss's Avatar
Checked it out this evening,as I suspected,it ran off the cord when powered 'UP". I can re- thread it and it pulls antenna down properly.Turn on radio,antenna goes up and off cord. When I get the new mast in a day or two, I think it will work fine. Thanks all.
Old May 9, 2011 | 11:22 PM
gdog's Avatar
Yep, exactly! If you wanted to open up the antenna mtr box you'll find several inches or more piece of broken "cord" as you call it.
Old May 10, 2011 | 01:39 PM
I thought you were having a problem with a new mass.
Old May 11, 2011 | 06:19 PM
budruss's Avatar
Received mast today, installed works perfect. This Ebay seller Rocks! OEM mast, $16.95 inc. shipping, 2 1/2 days, Wisconsin to Ca.! Thanks once again to all the responses....Russ
bsobo
Apr 20, 2010 08:18 PM
alecw81
Jan 7, 2009 05:22 PM
Wing
Jan 31, 2008 10:13 AM
snulma1
Sep 25, 2006 09:04 PM
armoredsaintt
Feb 18, 2004 01:54 AM
