850 Turbo Wont Start
Old Jan 19, 2011 | 02:22 PM
Mevans850Turbo's Avatar
Default 850 Turbo Wont Start
Hello,
I am a proud owner of a 1995 850 Turbo Wagon. For one reason or another it will not start. The usual warning lights like check engine, abs, oil etc will not come on. Also I don't here the fuel pump buzzing either and neither the Turbo, oil pressure gauge moves. What could possibly be wrong?
Old Jan 19, 2011 | 04:23 PM
91shelby's Avatar
Does it turn over? Are you getting fuel to the rail? Use the Check valve at the end of the rail. Spark?
Old Jan 19, 2011 | 05:32 PM
maxxum's Avatar
I had this trtouble with my 850.
After i replaced the crank angle sensor and the cam angle sensor it would still not start, I then replaced the fuel pump relay. It now starts.
The relays are under and behind the fuze cover. Remove the screws and lift off the main cover and you will see the relays. The relay is called " FUEL PUMP CONTROLLER"
Old Jan 19, 2011 | 06:15 PM
ibified's Avatar
will the engine turn over when you turn the key? you didnt specify.
Old Jan 20, 2011 | 09:35 AM
boxpin's Avatar
I suspect if your cluster lights are not lighting up when you turn the key that your ignition switch may be bad. Can you tell us more about what does or does not work when you turn the key. Example: Does the car crank (like ibified said), does the radio turn on, interior fan, headlights, wipers....check all these things. A video of you turning on the car would help a bunch.
Old Jan 20, 2011 | 10:18 AM
ibified's Avatar
Boxpin: that's what i was getting at....especially since the switch seems to be a common issue.
Old Jan 23, 2011 | 01:09 PM
the motor does turn over but does not crank. The car will not start. The radio does work but the cluster of lights that come in when you turn the ignition does not. Also the fuel gauge, turbo gauge and temp gauge do not work.
Old Jan 24, 2011 | 01:31 AM
gdog's Avatar
Still confused????
Oh wait a minute.. Does this mean you can manually turn over the engine but the starter won't turn it over?
Given the other stuff that doesn't work too, sounds like something basic in electrical system is bad; like battery or ignition switch... you'll have to ck voltages...
suze
Jan 30, 2014 07:42 AM
Fern Schmidt
2001-2013 model year V70
Aug 13, 2013 06:43 PM
boosted8fifty
May 27, 2009 07:44 PM
boosted8fifty
May 23, 2009 01:56 PM
furball3
Jan 28, 2007 03:31 AM
