850 wagon oil leak
Old Feb 3, 2007 | 08:12 PM
werkhaus's Avatar
Default 850 wagon oil leak
I am working on a 1997 5 cyl. There is a significant oil leak on the exhaust manifold side of the head. (at the corner of the #5 cylinder). Prior to the oil leak, the car had stalled out and was towed here (it's my sister's car). I found a lot of oil on top of the valve cover gasket and also in the distributor cap. The ignition was killed by the oil. 3 of the five plugs were oil soaked. I replaced the plugs, cleaned the distributor cap, cleared the fault codes (cylinder misfire codes). The car runs fine and does not miss, but the oil is coming from that side of the head at a steady clip.
Is it possible that i have an overpressurization problem in the oil system? Has anyone seen this issue happen?
I am going to do an oil pressure test, but I can't seem to find the oil pressure sending unit...where is it?
I don't know if doing a compression test will tell me anything.
Got any suggestions? I'd appreciate any and all!
Old Feb 3, 2007 | 08:17 PM
Default RE: 850 wagon oil leak
Is it turbo or Non?
The Cam seals are common for leaking thats why the cap was soaked with oil.
But that usually happens from the Vent box being clogged.
If it is a Non-turbo clean the flame trap and make sure all hoses are free.
I would replace all 4 cam seals.
740turbowag
Jan 29, 2015 07:41 PM
benspeeder
May 26, 2011 07:10 PM
ROBLU540
Feb 20, 2009 07:59 PM
Dobbersky
Apr 17, 2008 09:51 PM
GaryBrad
Aug 12, 2005 12:48 AM
