850 wipers gone wacky
Old Dec 19, 2005 | 12:17 PM
kwik850's Avatar
Default 850 wipers gone wacky
So I have come across a problem with both 96 850's I have owned. The driverside windshield wiper comes off the windshield when it gets to about 75-80 degrees in its upward swing. When it did this on my sedan, I attributed it to whomever replaced the windshield bent the linkage, but then the other week I turned on the wipers in my wagon and discovered it was leaving the windshield at the same spot and my wagon has the original glass in it. Living in Arizona dose'nt neccessitate using the wipers all that often, maybe once a month outside of monsoon season, but when I do need them it would be nice to be able to see without having to gangsta lean. Is this a common problem and if so is there a cheaper fix than new linkage?
Old Dec 19, 2005 | 02:51 PM
JimKW's Avatar
Default RE: 850 wipers gone wacky
My 97 850 does the same thing. I did not notice on my 94 850 nor on my 98 V70. The blade actually comes off the windshield on the far left side on the 97. I drive in rain quite a bit and it's a nuisance. I think it is a known problem, but I don't know of a solution.
Old Dec 19, 2005 | 07:48 PM
B1mmer's Avatar
There are two options:
1. Buy a new wiper arm from a dealer
2. Click Here
I used #2 and it's worked great. I took mine off though and bent it in a vise. - AB
Old Dec 19, 2005 | 09:52 PM
Yes remove it and stick it on a Vise and give it a hair of a bend just above the hole in the arm.
Caution it is made of POP METAL which will break if pushed to hard. Just kind of lean on it a little. Then try it and see if it is better.
Old Dec 20, 2005 | 02:32 PM
tomservo's Avatar
Hell, I just left mine on the car and bent it gently, then tightened the nut, and it's been fine since.
Old Oct 11, 2006 | 01:35 AM
JPN's Avatar
JPN
Hi,
No one may read my reply, as the original message was posted in 2005.
I had the same problem with my 1994 850 Turbo T5 sedan. What I did was to use a "half-washer". I cut a washer in half, and installed it between the wiper arm holding nut and the arm. This way, the wiper blade is installed at an angle and stays on the windshield. Make sure to do it the correct angle, otherwise the wiper will stay off regardless of the position.
Regards,
JPN
Old Oct 11, 2006 | 01:33 PM
JimKW's Avatar
I did just what tech suggested in the vise and it fixed the problem.
dmg4
Jul 13, 2013 06:55 PM
DeadLast
1998-2000 model year V70
May 9, 2013 04:04 PM
macedon
Jun 7, 2010 09:28 AM
Moparman
Jun 16, 2006 04:16 PM
mccreadys4
Dec 22, 2005 12:42 PM
