850R, blue tune, doesn't want to run after WOT pull
Recently installed an 18T turbo, and ARD blue tune. After a hard pull at WOT I heard some popping, like predet or unburned fuel(note: this happened only after I put the blue tune in, at WOT); then after I let off the issue started. It started bogging and didn't want to let me go over 1/4 throttle or 2k RPMs, and I had to go 20 mph to get it off the freeway. It ended up dying in a parking lot a few miles down the road. The idle was surging and there was no CEL.
I put in my old stock ECU and it ran OK but still idled like this. CEL is from me unplugging the MAF and plugging it back it, not from the idle issue. Ran ok for 4 miles with the stock ECU, just didn't want a lot of throttle or it would cut out.
I've already tried unplugging the MAF, no difference. I'm thinking it's a fuel issue, either regulator or pump because no CEL was thrown but it smelled like it was running VERY rich after this problem started.
Here's a vid of the idle, stock ECU
Volvo 850R idle issue - YouTube
Vacuum seems good, solid 17-20 at idle. I checked everything under the hood as well.. No hoses popped off, injectors are seated firm, looks normal.
The fuel pump would not be a likely problem if it was smelling rich.
The regulator on the other hand can rupture and allow the engine to suck in raw fuel through the vacuum hose connected to it. Try pulling the hose and starting the vehicle to see if any drips out the regulators nipple.
And life is good again !!
Glad it was only a loose hose and not some electronic gremlin.
You know you're in trouble when you're trying to run new wire and you can't tell the new from the old !!
That is my nightmare!! I hate wiring!
It seriously made my stomach drop. Like I thought something catastrophic happened at first, especially on the busy freeway on a saturday night, NOT GOOD
Vmax
Apr 7, 2014 07:42 PM
GeneAlexander
Nov 16, 2006 06:59 PM
