850r, random overheating
Old Sep 16, 2013 | 12:13 PM
  #21
1+, I recently learned that. When a car over heats, it will cause the weak link to burst. All the heat and pressure.
Old Sep 16, 2013 | 04:58 PM
  #22
I've always thought if you had a cooling problem you had a problem you needed to cure. I've never looked at the thermostat by itself as a cure.
I need to be clear. In your case it might only be a thermostat and the thermostat would be the cure.
I'm talking about having a working thermostat and an overheating problem and trying to fix the overheating problem by using a newer cooler thermostat. It will open sooner but the "problem" will still drive the engine to overheat.
850rt5
Dec 6, 2013 05:46 PM
lavalva
Sep 26, 2007 11:10 AM
JeremyR
Aug 3, 2006 05:36 PM
mozhan
Dec 1, 2004 06:38 PM
miami_twice
Dec 22, 2003 01:02 PM
