Random Speedo Problems
Old Aug 28, 2006 | 12:59 AM
lavalva's Avatar
Default Random Speedo Problems
Hello All,
I'm having some intermittent speedometer problems in a 1998 S70 GLT. Very simple... Sometimes the speedometer just doesn't work. 99.9% of the time it doesn't work from starting the car. However, if I turn the car off/on again it always seems to work again. All other gauges work fine all the time.
I'd say it's about 40% of the time it doesn't work when starting the car. The other 60% it works after turning the car off/on again.
Not sure if this helps the diagnosis; But when the speedo isn't working, the cruise also doesn't work. I just had the car scanned last week, and it scanned clear.
Any ideas of what this could be? It's not urgent at this point, but I'm thinking about taking it in to get it checked out. I figured I'd ask around first.
Thanks!
Old Aug 28, 2006 | 08:57 PM
Default RE: Random Speedo Problems
Is the ABS light on?
Also have you tried wiggling the key after it is running without turning off the car?
Old Sep 2, 2006 | 01:20 PM
JAKESTERS's Avatar
Try the moving the key switch ,like tech said. I had the same issue and replacing key switch worked.
Old Aug 4, 2007 | 01:24 AM
lordhowe's Avatar
any body have any more feed back on this? i'm seeing the EXACT same thing
Old Sep 26, 2007 | 09:09 AM
mark_disfree's Avatar
I am also having the same speedo problems. With mine, I usually get the ABS light & theBRAKE light but then seemingly for no reason the speedo will just start working again. When this happens the original warning lights will go off but thenthe Trac Control Light will come on.In the beginning I had only the ABS light and Trac contro light coming on for about 2 weeks, then the speedo started cutting out and I would get any combination of ABS, BRAKE, check engine, falshing arrow, STC,andmileage displays -----
. Also sometimes things go bad from the moment I start it other times it willbe fine at start but then go bad while driving down the road. In the beginning there seemed to be a connectionbetween hitting a bump in the road and the lights coming on.
From whatI read this soundsmost likey the like the ABS module, butI alsoread it could be the key switch or a battery cable in a relay box. Do these sound like possibilities to you? Any thought on how I can narrow it down?
Oh yeah anyone have contact info on someone who rebuilds/fixes the abs module?
Old Sep 26, 2007 | 11:10 AM
99VolvoV70's Avatar
With credit to Tech, since he's posted this in the past. Here's a (the?) guy who does ABS rebuilds. I need to send mine out sometime soon.
http://home.earthlink.net/~vicrocha/...vo_V70_ABS.htm
questionv
Jun 19, 2013 10:57 PM
eyyu
Oct 27, 2007 10:42 AM
eyyu
Oct 25, 2007 10:08 AM
kurtz075
Mar 2, 2007 01:17 PM
brianjwagoner
Mar 5, 2006 01:26 AM
