'93 A/C fan switch R&R
Old 07-22-2007, 07:28 AM
stecz's Avatar
Default '93 A/C fan switch R&R
the fourth speed on the fan switch doesn't seem to work, I assume I need to swap out the fan switch (it has manual A/C).
Is the switch a separate part I can replace? I've never taken the dash apart on this car, any pointers on that?
I may just try cleaning it with contact cleaner if I can get it apart.
Thanks,
Old 07-22-2007, 08:03 AM
JPN's Avatar
JPN
JPN is offline
Default RE: '93 A/C fan switch R&R
Hi,
Removing the A/C unit from the dash is not difficult, but you may need to remove the radio first, in which case you need to know the reset code for the radio. After the radio is out, you can press on the tension springs that are holding the A/C in place. After that, all you need is a #2 Phillips screwdriver.
Or, it could be the resistor (power stage), if cleaning does not solve the problem.
I hope this helps,
JPN
Old 07-22-2007, 08:42 AM
The MCC panel comes out a little different then described above.(Sorry JPN)
Remove the 3 radio *****. Then remove the 2 screws. Then you will be able to slide the panel out. It might help to slide the radio out leaving the wires attached and pushing on the plugs for the panel.
Old 07-22-2007, 05:29 PM
JPN's Avatar
JPN
JPN is offline
Tech, I sucked.
JPN
P.S: But babies suck too, don't they[8D]?
Old 07-22-2007, 05:54 PM
You tried!!!
You have it 100% correct for a ECC system.
Old 07-22-2007, 06:08 PM
JPN's Avatar
JPN
JPN is offline
Tech, thank you for that. I feel less ashamed now.
JPN
Old 07-22-2007, 06:22 PM
LOL.... you guys are a riot :-)
My memory is fuzzy on this but is there a relay under the dash
that is used only for the highest blower speed?
Best regards, John
Old 07-22-2007, 06:51 PM
On some of the cars yes but not on all of them.
Old 07-23-2007, 06:07 AM
It's good to learn new things, thanks tech.
John
mnvolvo
03-01-2012 11:16 AM
bennyd20
09-23-2011 07:34 PM
Crispin
03-17-2011 02:17 PM
woodworker
06-20-2005 08:09 PM
Quick Reply: '93 A/C fan switch R&R
