93 Non turbo dies ocassionally
Old Nov 9, 2010 | 09:49 AM
Just Jim's Avatar
Default 93 Non turbo dies ocassionally
Car usually starts no problem, but sometimes after driving it just dies. After waiting 5-10 minutes, car will restart and run fine. Is it the fuel pump relay? Is it a dealer item only? Also would like to tune it up today, any recommendation of parts I should buy? Does it have points and a condenser, or is it electronic? Thanks
Old Nov 9, 2010 | 12:32 PM
hookuspookus's Avatar
Default hi
sounds like a bad ignition modual , when it gets hot a transistor gets hot and shuts down ,when it cools it turns on
Old Nov 10, 2010 | 07:53 AM
Rickford's Avatar
Default Fuel pump relay.
Had EXACTLY the same problem on my 94 850 Sed non turbo. Got a new FP relay and so far so good. Does it stall just after getting gas by any chance? Mine did but not any more. Hole this helps. Dealer had one for $55, bough that one instead of on line for about $25.
Old Nov 14, 2010 | 09:28 AM
Just Jim's Avatar
Change FP relay and tuned it up. Still dies occasionally, doesnt seem to have to anything with getting gas. Tried to buy an aftermaket FP relay, but it was a little larger and had round electrical tabs, not the flat blade types. $60 from dealer.
Old Nov 15, 2010 | 05:30 AM
Rickford's Avatar
Next logical choice is a new/used FP, but not cheap. That being said, it could be a host of things. just saw a used FP on ebay for a start bid of $100. You now need to check fuel pressure when it stalls for starters. Read you can hook up fuel pressure gauge at the fuel rail and route it into the car to see while driving. OR just try a different pump. Best I can do! Rickford.
Old Nov 15, 2010 | 05:35 AM
Rickford's Avatar
Also herd a lot about the ignition switch going bad and causing a no run problem. Try giggling it to duplicate the stall...
Old Nov 15, 2010 | 07:28 AM
boxpin's Avatar
+1 here on the fuel pressure, before you go buy a fuel pump test the rail pressure before and during the death.
Another question, when it dies does your Tach just drop suddenly? Meaning, have you lost spark? If it just goes down with the RPMs of the engine then your probably still firing and your looking at a fuel issue. If it suddenly drops to 0 then you probably lost your spark. Anyway, easy first test.
chithodt
Jun 11, 2015 11:20 PM
Ablorx
Jul 4, 2014 08:33 PM
free1959
Sep 11, 2011 02:59 PM
dece207
May 6, 2005 12:47 AM
JMyerz
Oct 10, 2004 09:47 PM
