93 non turbo stall randomly
Old Oct 30, 2008 | 11:31 AM
djamp1983's Avatar
Default 93 non turbo stall randomly
At completely random times while i'm driving my car will simply die as though i turned the key off. it doesn't matter if i'm going slow or fast, hot or cold, uphill downhill... the list goes on. once i have come to a complete stop, and try starting the engine up right away it will just keep turning (i can hear it firing, but not enough to sustain itself). abut two minutes later it will start up and run like nothing is wrong. sometimes if the road is empty enought for me to not have to move to the shoulder, i can floor the accelerator and the engine will catch usually by the time it has downshifted to second gear. I have replaced the fuel filter, air filter, spark plugs, plug wires, distributor cap, and ignition coil.the check engin light won't come on, so i can't run the error codes. any ideas what is making my engine do this?
Old Oct 30, 2008 | 09:56 PM
Quick Brick's Avatar
Default RE: 93 non turbo stall randomly
Hey now Djamp1983,
Around the middle of the summer I experienced a similar issue. It got to the point where I knew that it was going to happen just by the way the car sounded and even flooring it wouldnt prevent it from happening. I seemed to luck out though and only stalled once in traffic. Other times I was on a side street and not going very fast. I also noticed from time to time that my speedometer would drop to zeroand a smack to the top of the cluster would sometimes bring it back. Most times Id have to stop and restart the car.
I never did figure it out and what ever was causing it has seemed to correct itself as it hasnt happened in some time.
Sorry I cant be of more help but fear not, youre in good hands here and more help is on the way.
[sm=icon_cheers.gif]
Old Oct 31, 2008 | 07:46 AM
I would check the fuel pump relay first.
Old Oct 31, 2008 | 08:54 AM
JPN's Avatar
JPN
Follow Tech’s advice first.
Usually, no-start or dying on the 850s are caused by one or more of the following:
- Faulty fuel pump relay, as suggested by Tech.
- Faulty fuel pump itself.
- Faulty CPS (Cam Position Sensor)
- Faulty MAF (Mass Air Flow sensor)
- Neglect, etc...
And sometimes one or more of these faulty sensors do not seem to trigger CEL.
Refer to the attached.
Let us know how it goes.
JPN
[IMG]local://upfiles/6892/93E85E07C7EF44B4BDEE39FB60C89440.jpg[/IMG]
[IMG]local://upfiles/6892/3290410EB01144F79FA23546E49FDB9E.jpg[/IMG]
[IMG]local://upfiles/6892/78564B4DF9F14148BF3E9BA63BDF4C17.jpg[/IMG]
[IMG]local://upfiles/6892/844A3901417A47C29C1DD47062CBFDBA.jpg[/IMG]
[IMG]local://upfiles/6892/78177D15DC204AAEB75E7853D621EC33.jpg[/IMG]
Old Oct 31, 2008 | 08:55 AM
Psaboic's Avatar
Since you have replaced the filter, plugs, and coil, I would check all the connections and look for a iffy wiring. If that turns up nothing, I would suspect the fuel pump relay, or the crankshaft position sensor
Old Oct 31, 2008 | 08:57 AM
Psaboic's Avatar
Correction, I meant to write camshaft positioin sensor, not crankshaft position sensor. I have crankshaft on the mind for some reason today!
Old Oct 31, 2008 | 10:47 AM
djamp1983's Avatar
thanks for all of your help, i've driven myself crazy checking over all the wiring thinking i may have missed something. fuel pump is only about 18 months old and so is the relay, MAF isabout a month older than thoes, theyall seem tofunction properly. how would i be able to tell if my cam sensor is faulty or not. the car is down for a few days waiting for a new tie rod to show up, so i can wait untill then to look closer at this issue.
Old Oct 31, 2008 | 10:58 AM
The plug for the cam sensor usually falls apart. Check that.
Old Oct 31, 2008 | 11:52 AM
djamp1983's Avatar
about six months ago my timing belt broke. could that have damged the sensor itself?
Old Oct 31, 2008 | 11:58 AM
I Doubt it.
Follow the wire from the Cam sensor to the plug and inspect the plug.
Old Nov 1, 2008 | 04:58 AM
JPN's Avatar
JPN
FYR.
JPN
[IMG]local://upfiles/6892/40E4EDA59B624EC48D92E9F18203C7ED.jpg[/IMG]
Old Nov 4, 2008 | 06:35 AM
djamp1983's Avatar
I took a look, and the plug for my cam sensor seems to be fine. everything is intact and there's no corrosion on the terminals. Is there a way i can test it to make sure?
Old Nov 4, 2008 | 07:35 AM
If it looks good I doubt that is it.
Old Nov 4, 2008 | 12:39 PM
djamp1983's Avatar
got a cam sensor from my uncle's salvage yard for free. i suppose i'll know in a month or so if it works.if it doesn't, i guess i'll have to bite the bullet and try a new one. thanks again for all of your help.
Ablorx
Jul 4, 2014 08:33 PM
mikkowus
Nov 13, 2010 06:56 PM
wlbirch
Jun 14, 2010 07:24 AM
white83glt
Jun 11, 2010 01:43 PM
jwandhistools
Aug 11, 2009 09:43 AM
