94 850 non-turbo running issues
Old Nov 25, 2012 | 05:47 PM
hall_gamma712's Avatar
Default 94 850 non-turbo running issues
I recently acquired a 94 850 non-turbo, my first Volvo. While driving home today the check engine light came on. Checking the codes when I got home revealed a 1-2-1 (Manifold Absolute Pressure (MAP) signal absent or faulty) code and a 2-3-2 (oxygen sensor control/long term fuel mixture too weak at idle) code.
First off, after researching am I correct in my conclusion that the 94 850 does not have a MAP sensor but a MAF sensor? Most of the issues with these codes I have found instances of online seem to come down to a bad MAF sensor and that was my initial suspicion. My car was running fine down the road but began idling rough while doing diagnostics (bouncing around in the 600-800rpm range). Clearing the fault codes erased the 2-3-2 code but the 1-2-1 remained. Following some suggestions I found on the forum I tried to isolate the issue in the MAF sensor if it was there. Unplugging it's electrical connection while the car was running resulted in it stalling out immediately. From what I found, the car should have still run with it unplugged. Another suggestion I found was that the coolant temperature sensor fails and more errors precipitate from that. Any ideas what is going on here? Thanks.
Old Nov 25, 2012 | 07:19 PM
The first thing you should do is read the "New 850 Owner" thread.
My suggestion is for you to check your vacuum lines and elbows.
Old Dec 29, 2013 | 12:50 PM
JayRW's Avatar
'94 850 no turbo, will not idle; on occasion after warm up.
Old Dec 29, 2013 | 11:18 PM
gdog's Avatar
My advice to you would be...
..start a new thread!
Ablorx
Jul 4, 2014 08:33 PM
Keith Tobberman
Sep 30, 2011 10:36 AM
white83glt
Jul 6, 2010 04:01 AM
ferrell450sel
May 12, 2008 10:11 PM
