94' 850 non-turbo service
Old Oct 29, 2005 | 03:28 AM
Red XC's Avatar
Default 94' 850 non-turbo service
Wondering what does the 94 850 sedan non turbo needs for service at about around 109k miles?
or can someone tell me how to read this:
http://www.volvocars.us/Volvocars.We...ACHEHINT=Guest
Old Oct 29, 2005 | 12:06 PM
Default RE: 94' 850 non-turbo service
The 110,000 service is pertty much just an oil change. 100,000 was the timing belt. 120,000 is the major tune up service.
EDIT: You have to check about the timing belt. Some 94's were 50k timing belts and others are 70k timing belts.
Old Oct 29, 2005 | 12:54 PM
robert213's Avatar
Also, a good time to verify that other maintenance items were done...
1) drain & fill (not flush) automatic trans fluid
2) check pads and rotors. replace, if needed. do not turn rotors
3) drain & fill coolant. replace thermostat. replace hoses.
4) check belts and idler pulleys. replace, if needed.
5) purchase a stack of oil drain plug crush washers.
Old Oct 29, 2005 | 03:58 PM
Red XC's Avatar
tech where can i get the info about the 50 or 70k for the timing belt?
70,000 MILES:
TIMING BELT ('94 -'97 models): REPLACE -
Replace worn belts to avoid belt failure while driving.
Old Oct 29, 2005 | 04:19 PM
Some early 94's were 50k belts. You would have to get the engine # of the timing cover or the block to find out 100%.
Old Nov 2, 2005 | 02:47 AM
Red XC's Avatar
the car has 117k miles.. should it be oil and filter change?
http://apps.volvocars.us/ownersdocs/...intenance.html
Old Nov 2, 2005 | 08:30 PM
Yes it should be oil and filter change and general check over.
Old Nov 3, 2005 | 03:30 AM
Red XC's Avatar
THanks tech, I'll ask my customer to drive the car to my house over the weekend for service.
Old Nov 13, 2005 | 04:09 PM
Red XC's Avatar
tech i found the engine # for that car
B5254S, last timing belt change was 70707.
Can you tell me when does the 850 engine need timing belt replacement?
Also, there is like a buzz near the throttle with key on, eng off.
Ticking at idle, could be the valves?
Old Nov 13, 2005 | 11:21 PM
The timing belt interval is 70,000 on that car.
The humming with the key on is the idle motor.
The ticking might be the oil pan o-rings.
Old Nov 14, 2005 | 01:56 AM
info2x's Avatar
ORIGINAL: tech
o-rings can tick? hmmmmm
Old Nov 14, 2005 | 08:44 PM
ORIGINAL: info2x
ORIGINAL: tech
No the o-rings go bad causing low oil pressure and the Lifters tap from low oil pressure.
Ablorx
Jul 4, 2014 08:33 PM
Keith Tobberman
Sep 30, 2011 10:36 AM
silverstreak98
Jul 5, 2011 07:37 AM
wvuboy0207
Feb 3, 2009 03:09 PM
chachouu
Sep 7, 2008 10:24 PM
