94 850 turbo
Old Aug 6, 2016 | 06:21 PM
brance's Avatar
Default 94 850 turbo
Car suddenly started running very roughly and stalling.Now it's throwing numerous codes.315 evap,543 miss on at least one cyl.,454 miss#4,542 misfire on more than one cyl.,143 front knock sensor,452 miss#2,433 no rear knock sensor signal,451 miss#1,455 miss#5. I'm thinking either a lack of fuel or spark.
Old Aug 7, 2016 | 11:09 AM
tryingbe's Avatar
Do a compression test first.
Old Aug 7, 2016 | 08:32 PM
brance's Avatar
OK thanks, I hadn't thought about that. Wow,this could get expensive very quickly.
Old Aug 8, 2016 | 07:15 AM
I'd start with a visual check of the vacuum lines - starting at the vacuum tree under the throttle cable spool, check for air leaks on the intake (from turbo to MAF) then consider measuring fuel pressure at the rail. You can also inspect the wires by looking at the date codes - if over 5 years old consider new wires and look at the rotor, cap, plugs (I've seen a cracked distributor cap do this kind of stuff...).
Old Aug 8, 2016 | 08:52 AM
brance's Avatar
Thanks for the replies guys, we're in the process of painting the entire inside of the house,tearing out the old carpet,trying to find places for all the furniture and work full time,so i'm struggling to find time to look at the car.The vacuum lines and the intake tube all look good,but I haven't got to the plugs and wires yet.
Old Aug 15, 2016 | 11:52 AM
brance's Avatar
OK,the plugs and wires are in horrible shape, now I just need a little luck and a lot of money. Central air unit went out last week so I have no idea when i'll be able to buy parts for the car.
Old Aug 15, 2016 | 01:18 PM
you can save some buying online. I'd start with OEM copper core plugs (850Ts prefer them to the expensive plugs), a wire loom set, distributor cap and rotor for the ignition. FCP Euro, EEuroparts, IPD USA all sell kits to save a few bucks.
Old Aug 22, 2016 | 08:58 PM
brance's Avatar
Thanks for the info mt6127, hopefully nothing else breaks, between the house paint,new carpet,trim,lights,furniture and central air unit i'm about over it. All that money sure adds up quick!
Keith Tobberman
Sep 30, 2011 10:36 AM
1Gray760T
Nov 13, 2009 08:19 PM
eddiecortes112683
Feb 22, 2009 08:37 AM
Keith Tobberman
Oct 23, 2007 08:33 AM
pvolvoman
Aug 14, 2006 12:48 PM
