94 850 Wagon Max Fan Relay Hot, speed 4 not working
Subscribe
Nov 25, 2019 | 07:56 PM
Hello,
My 94 850 wagon (with the MCC) has always worked on blower fan speeds 1-3, but never worked well on fan speed 4. By pulling the max fan speed relay from behind the glovebox and putting it back in, I can get speed 4 back for a short while, but usually after a few minutes it will stop. I've recently noticed that the relay gets very hot after these few minutes, plug 87 is a bit charred. Worried that it may be a bit of a fire hazard. Please see pictures.
Is there an obvious reason why its doing this? I tried replacing the relay but it did not solve the problem. Could there be an issue with the resistor?
Cheers
Reply 0
Nov 27, 2019 | 09:08 PM
The charring is caused by the blower motor pulling too much current at full speed. I suspect a dirty, or failing blower motor. When the motor gets old, dirty, or otherwise starts to bind a little bit, it will take more and more current to spin it. Get a replacement motor and I'm betting your issue goes away!
Reply 0
Subscribe
