95 850 coolant problems
Coolant has been going somewhere. I cant see a leak. Radiator is leaking some but looks like oil. Drained all the fluids, no coolant in the motor oil, transmission fluid looks coolant free. Took it to a shop and they said "fluids are combining, must be a head gasket. You need a new motor" yet motor oil is free of coolant. No smoke nothing leads me to a head gasket.
Plans are to replace the radiator (ordered just waiting for it to come in), but i really need to find where the coolant has been going. Refilled the coolant res 3 times in 4 days and parked the car. Also some oil has made its way into the coolant res. Any ideas?
Compression test will show head gasket leaks. You can also get a tester kit from your local auto store.
Compression Test - Volvo S70 GLT, 1998
Remember, check your res while the car is cold. Should have a little coolant in there.
carson850
01-07-2014 02:08 PM
aru5016
06-19-2011 12:26 AM
