95 850 has trouble starting
Old Jan 20, 2009 | 07:22 PM
slowrider06's Avatar
Default 95 850 has trouble starting
My 95 850 can start without an issue over and over and than wont start. I hear a click and then a sound as if a spark was generated and failed. I would wait a few moments and then try again and then it usually starts.
Today I almost had to leave my car at work because it took about 2 dozen tries before it finally started. The battery is in good shape.
I was told it is more than likely the starter relay. I see it is on the starter motor. Can the soleniod be replaced by itself or is the starter and solenoid one unit?
Can anyone tell me how easy/difficult the soleniod and or starter is to replace?
Old Jan 20, 2009 | 07:47 PM
Default RE: 95 850 has trouble starting
I would buy a Bosch starter and swap it out. Its not to bad to replace.
Old Jan 20, 2009 | 08:43 PM
96850urbo's Avatar
Do you have to take off the intake manifold to swap it or can you just go right at it?
Old Jan 20, 2009 | 08:49 PM
If the car is a turbo I reccomend removing the cooling fan.
If is is not turbo you can usually get right in there and remove it.
Old Jan 21, 2009 | 02:52 AM
JPN's Avatar
JPN
FYR, the 2nd pic is a courtesy of Robrike.
JPN
[IMG]local://upfiles/6892/09827483BC84423684F38827703A7BB8.jpg[/IMG]
[IMG]local://upfiles/6892/9941230EAD944106984DFC5996781225.jpg[/IMG]
Old Feb 2, 2009 | 04:53 PM
mygreat850turbo's Avatar
I have installed a rebuilt Bosch starter, hoping that would start up the car.
But it is still making the same kind of whining sound as with my old starter.
Did I install another bad starter or what else would cause that whining sound?
Any idea?
Thanks!
96 850 Turbo - 126K miles
Old Feb 8, 2009 | 08:39 PM
tripwire1969's Avatar
Same deal here. Car almost starts, and then a whirring sound. Sometimes just the whirring. When car comes close to starting, it backfires, and dies. Already replaces the cap-rotor, plugs, cam sensor. Car started once a few days ago, and ran good for half an hour; I put it in gear and stalled. Hasn't started since. (Also changed oil and filter...).
Old Feb 9, 2009 | 09:26 AM
wooper999's Avatar
Default relay
hi there
VERIFY that the INJECTOR relay on top of the RAD
(to the right of the turbo intake hose--if you have one)
is functioning.
get someone to touch it with their fingers
while you try to start the car.
if they feel a click its probably ok
and soo look elsewhere for your problem
if no click...get a new one for around $40
I discoverd this while working on my car...
if that isnt plugged in or working order
my starter would WHRRRRRRRRR
but NOT engage...but as soon as I plugged it back in---wroooom
away she went.
lemme know
Cristian7
Aug 14, 2011 02:39 PM
DaftGent
Jun 12, 2011 03:46 PM
d33dvb
Jan 13, 2010 10:46 PM
srayburn
Jan 14, 2008 09:57 AM
sagi122
Oct 8, 2006 10:54 AM
