95 850 turbo timing belt help
Old Nov 24, 2008 | 02:57 PM
Benihana's Avatar
Default 95 850 turbo timing belt help
I
don't know if my timing belt has ever been changed, it has 94k miles and this is what the belt is/looks like. Is this the original belt or a replacement?
Old Nov 24, 2008 | 07:34 PM
Default RE: 95 850 turbo timing belt help
That is a replacement belt.
Old Nov 25, 2008 | 07:31 AM
JPN's Avatar
JPN
And that is the OEM belt as well. If you are concerned, check the roots at each tooth with a strong flash light to make sure that there are no cracks.
JPN
Old Nov 25, 2008 | 10:06 AM
Benihana's Avatar
the teeth look fine to me. I just don't know what a timing belt with almost 100k miles looks like. I ordered one anyway yesterday, i can compare when it arrives i guess.
Old Nov 25, 2008 | 01:42 PM
From what I see in the pics it looks pretty good.
Most likely someone replaced it at 70K.
It is an aftermarket belt but they make OEM belts if it hadn't been changed it would be a Volvo belt.
Old Nov 26, 2008 | 08:27 AM
Psaboic's Avatar
If in doubt....Change it out. It is not that expensive compared to a new motor if the belt breaks. Just my .02
Old Dec 12, 2008 | 06:22 PM
Deanolsen's Avatar
Gosh darn, you can pay a meachanic to change that belt for about $200. (I just did.) It really is worth the peace of mind. If that belt goes, you may as well junk the car.
Old Dec 12, 2008 | 11:06 PM
chef's Avatar
Hey there...how did you manage just to pay 200.00$$??? i once did a timing belt and water pump on one of my cars...came out to about 800.00$....which made me wonder...on volvo's is it like most cars that you also change the water pump at the same time? what else usually gets changed? any pulleys/tensioners??? thanks
fab
Old Dec 13, 2008 | 10:09 AM
JPN's Avatar
JPN
The genuine Volvo water pump is almost indestructible. Mine, however, had a minor seepage of coolant so I replaced with a German aftermarket (HEPU) pump.
Some components that may be replaced are:
- The idler pulley.
- The tensioner pulley (damn that Torx bolt[8D])
- The Hydraulic tensioner cylinder.
- The Water pump, only if it is leaking.
JPN
Old Dec 13, 2008 | 10:33 AM
chef's Avatar
JPN thanks the reply...i didn't know the waterpump was that tough....i know that on most cars it's automatically done when changing the timing belt...I know that i'm not loosing any coolant but i notice on my dash that what when the engine is warmed up the needle is usually just a bit over the halfway mark...i'm thinking now that it could be the thermostat? thanks
fabs
Old Dec 13, 2008 | 03:19 PM
The Edge's Avatar
The impeller seal went on mine at about 175k and standing for 6 months before i bought it. I presume it was the origional and there was no play in the bearing at all.
Old Dec 13, 2008 | 07:51 PM
JPN's Avatar
JPN
If the coolant temp gage is slightly above 3 O’clock, you could defer the thermostat. However, if it has never been replaced it is not a bad idea to replace it. Make sure to use the OEM unit. There is O-ring to the thermostat and no gasket. I used paste-type gasket on the mating surfaces, though.
Yes on most cars the water pump is done with the timing belt. My 1988 Accord LX-i was no exception.
JPN
Old Dec 13, 2008 | 08:40 PM
wheelsup's Avatar
ORIGINAL: chef
fabs
Depends on the temp of the thermostat, I had an 87C in the car originally it was dead center now apparently Volvo only sells 90C and it's slightly above dead center, it kinda bothers me but I guess if everyone is buying 90C it shouldn't be an issue.
Old Dec 13, 2008 | 08:43 PM
wheelsup's Avatar
ORIGINAL: chef
fab
You overpaid...by a lot. I had my indy redo my timing belt for me and it was $430 that included the belt and the two pulleys, and another hour because I snapped an accessory belt tensioner bolt.
Standard procedure is every 70k to replace the belt every 140k to replace the tensioner, pulleys, and waterpump as well as the belt. But I think Volvo owners are kinda gunshy with pushing those items to their life limit because of the consequences if one item fails.
Old Dec 13, 2008 | 11:32 PM
chef's Avatar
Wheelsup..thanks for the replies..so maybei have the 90c in my car then, cause it's just a tad above the center. Do they make lower temp thermostats for our cars? might be good for summer time.
as for the timing belt, I did pay a bit, but that was on my 91 eagle talon...awesome car, but mechanically a nightmare!! the belt snapped and bent some valves, i have never seen a tighter engine bay like the talon's it was soo tight. i guess i will have the pulley's and tensioners checked when i have to change it...
thanks again
fabs
Old Dec 14, 2008 | 01:02 AM
wheelsup's Avatar
ORIGINAL: chef
thanks again
fabs
Oh OK I assumed it was a Volvo you were referring too, obviously with different cars all bets are off.
They make an 87C as well. FCP sells it, as well as EeuroParts.com. A member on here looked up the T-stat info on his Volvo software and it said to use a 90C now. I highly doubt 3C will effect anything long term. In fact if I recall correctly an engine that runs a bit warmer actually runs better and builds up less sludge.
When I changed my belt the first time I put a new pump and pulleys in. My engine was quiet afterwards, where before it had a minor squak. The waterpump was also rough to spin, although I didn't notice until after I took it off the car. I'm glad I replaced all the items, not only does it sound better but I won't have to worry about them breaking down the road. A member on here recently had one of their pulleys explode while idling. His engine made it but he was lucky!
Old Dec 14, 2008 | 10:09 AM
  #17
chef's Avatar
Hey Wheelsup..ya sorry i didn't mention before that it was another car's timing belt i was talking about. It was quite expensive to do, but as i mentioned it doesn't help when you have a tight engine bay..just tot give you an idea, to change the cone air filter in the car, it took me about an hour to change and put in a new one!!!! imagine what it would have cost at a garage! hahaha
The best was the caprice i had, if i needed to i could litterally stand inside the enging bay to do some work..it wasn't necessary most of the time but i could have. Big cars with big engines are the best to work on...i think after the volvo dies (knock on head), i will probably get another bigger car.
I will consider changing the pulley's and tensioners as mentioned...may as well once you're in there...i will probably do it at an authorised volvo garage though...i'm not that knowledgable. thanks
fabs
7zarc7
Mar 24, 2010 07:17 AM
04v70
Jul 17, 2009 11:01 AM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
