95 855turbo dash lights dead
Old Oct 20, 2008 | 10:10 AM
outdoor7or24's Avatar
Default 95 855turbo dash lights dead
Folks, been searching here for my issue. Dash have been going off an on a few times with me, but now they are not coming on at all.
I think it is the ignition switch, as I have to turn the key back to shift out of park, get the daytime lights on, and seatbelt lights to come on.
Is there any tests I can perform? I pulled the headlight switch and opened it up to see if there was any trash, there was none.
I guess I need to order the ignition switch that is on the keyed part???
Old Oct 20, 2008 | 10:31 AM
Default RE: 95 855turbo dash lights dead
The dimmer switch is a common problem. That is the backlighting for at night correct?
Old Oct 20, 2008 | 10:42 AM
ORIGINAL: tech
Yes tech, the backlighting in the dash - night or dark rainy days.....
Can I test the dimmer switch some how?
I know I need the electrical part on the ignition switch for sure.
Old Oct 20, 2008 | 11:08 AM
Its hard to test them. Alot of times they will do just like yours then be dead all together.
Mine in my Yellow one did the same thing just after I bought it.
If you have a junk yard near you try getting one there.
Old Oct 21, 2008 | 08:57 AM
Psaboic's Avatar
I agree with the dimmer switch. I'm betting it is either a loose connection (rare) or a dead switch. You might want to check the fuse to make sure it is in tight, just to be sure.
Old Nov 12, 2008 | 10:58 PM
Update: I have tried a different headlight switch and just installed a new ignition switch - electrical part... Now I get random lighting. If I pull the key out of the ignition quick and hear a good ding from sliding it out fast, and reinsert the key, the dash lights work in I, II, and then sometimes III. I swapped out the headlight switch to the old one and it seemed to do the same.
I lubed the key part with some WD-40 and that made the key slide in better, but still the same deal.
Could the electrical ignition part - 9447803 - be defective? It was brand new, in a sealed bag.
It seems like there is a contact problem between key section II and III. However, sometimes I would not get any dash lights when putting the key in.
Oh, are the dash lights supposed to work in parking mode, no key in???
Maybe a faulty dimmer switch, but it seems to do fine when dash lights are on. At least I do not have to turn the key back to get the car in gear....
Thanks for your help folks!!!
Old Nov 13, 2008 | 07:47 AM
I would try a new dimmer switch.
Old Nov 13, 2008 | 08:19 AM
Tech, I guess that would naturally be the thing to do next.
This AM I tried to see if the dash lights would work and they did fine. I moved the slider on the dimmer switch back and forth several times and it was okay [dimmed the lights like it should...].
Does the dimmer switch cause erratic behavior like this?
Thanks....
Old Nov 13, 2008 | 08:27 AM
Yes like I posted above my Yellow one did this days after I bought it.
Old Nov 17, 2008 | 06:15 PM
Default RE: FIXED 95 855turbo dash lights dead
FIXED!
Replaced dimmer switch.
QUEstion - When I put new switch in, my lights on the A/C on/off and recirculate on/off were blinking. They have done that one more time when I turned car off to position 2, and moved headlights switch to parking lights.
Any idea what this is? Normal???
Thanks for all the help.
Old Nov 18, 2008 | 08:57 AM
Psaboic's Avatar
The lights on the ac panel are a different issue. WHen they both blink it usually means there is a fault in the climate control system. You can do a quick search and learn how to pull the codes for the cliamte system. I don't know the procedure off the top of my head.
Old Nov 18, 2008 | 06:59 PM
ORIGINAL: Psaboic
+1
Ratphink120
Mar 11, 2022 10:41 AM
RoeRoe
Sep 13, 2010 08:30 PM
850GLE
Sep 22, 2009 10:28 AM
Cyburg
Aug 31, 2009 06:09 PM
BigAdam
Aug 24, 2008 03:18 AM
