Is '95 Non-Turbo OBD-II?
Old Jan 31, 2006 | 06:04 PM
jcmartin's Avatar
Default Is '95 Non-Turbo OBD-II?
I have the diagnostic block in the engine compartment, but it doesn't seem to do anything. -- no flashing LED, etc. Is it possible that I have both a diagnostic block and an OBD connector on a '95, and that the OBD is the one that actually works? Or is it possible that my diagnostic block is non-functional?
Thanks,
JM
Old Jan 31, 2006 | 06:51 PM
S70driver's Avatar
Default RE: Is '95 Non-Turbo OBD-II?
I am pretty sure my 1995 Volvo 850 n/a was OBD II.
Old Jan 31, 2006 | 09:25 PM
Look in front of the shifter by the cubby and Cigar lighter. Do you have a coin holder there? If so then you have OBDII.
Old Jan 31, 2006 | 10:05 PM
JimKW's Avatar
95 was a split year. Some were ODB-II and some weren't. If you have the coin holder the ODB-II plug is under it. It just lifts right out.
Old Feb 1, 2006 | 01:40 PM
rp850's Avatar
I have a 95 too and the weird thing is I have the OBD II port but it does nothing. The under hood diagnostic OBD-I is where I get all my info. Maybe my center console was replaced with a 96+ sometime before I had the car??? Who knows??
Old Feb 1, 2006 | 08:54 PM
Certain things can be done from the port on the 1995. Most of the time it is only read engine codes.
But then the rest will be done from under the hood.
Old Feb 2, 2006 | 10:04 PM
m1964's Avatar
I have early '95 (production year 1994) and both work.
dlaxdal
Aug 22, 2020 09:56 AM
chithodt
Jun 11, 2015 11:20 PM
Ablorx
Jul 4, 2014 08:33 PM
dece207
May 6, 2005 12:47 AM
JMyerz
Oct 10, 2004 09:47 PM
