95 volve 850 wouldnt start please help
Old Jun 2, 2008 | 12:17 PM
kozzy00's Avatar
Default 95 volve 850 wouldnt start please help
Slight problem, my girlfriend has a 95 volve 850 2.4l, non turbo.. She was driving home from work, got to the house, turned the car off came inside for like 30 minutes, went to leave again and the car would not start... I check for spark, it has spark in the coil and from the distributor to all 5 cyl. So, checking fuel and everything it was all fine, couldnt figure it out, let it sit over night and it started right up this morning, any clue of why this could be happening? Could it be that this tiny crack in the distributor cap is affecting this, or the crank shaft position sensor? ANy advice, will help so much
thanks and hope to hear from someone!
brian
Old Jun 2, 2008 | 12:32 PM
JimKW's Avatar
Default RE: 95 volve 850 wouldnt start please help
Sounds like you tricked your girlfriend into spending the night to me.
If it's getting spark it's not the Cam or Crank position sensor. My first thought would be that the fuel pump or fuel pump relay, but you said it WAS getting fuel. Did it crank normal or was it a little slow cranking? Has it thrown any codes?
Old Jun 2, 2008 | 01:04 PM
kozzy00's Avatar
haha, well it wont start agian she says shes sitting at home.. but, she says it smelled really gassy... it cranks normal and everything just wont start... could the small crack in the distributor cap be causing this?
Old Jun 2, 2008 | 02:09 PM
JimKW's Avatar
If it hasn't had a tune up for a while that's where I would start. New plugs, wires, dist cap and rotor couldn't hurt and it's fairly inexpensive. I would use OEM Turbo plugs. As a matter of fact I would use all OEM parts for a tune up. I have bought them from fcpgroten, the local dealer and volvoparts.com.
Old Jun 2, 2008 | 07:24 PM
JPN's Avatar
JPN
ORIGINAL: JimKW
+10.
I think the first problem is that it is "Volve", not "Volvo".....
....just kidding[8D].
I would replace the cracked dist cap. Also see if any trouble codes have been thrown.
JPN
[IMG]local://upfiles/6892/945391F8BEC04676BFBCE4D2945FFAC6.jpg[/IMG]
[IMG]local://upfiles/6892/A2658E4979634261BAF83EC2F2A2E5E7.jpg[/IMG]
[IMG]local://upfiles/6892/7D0763C5B6364D45B5C3E99ECD94155E.jpg[/IMG]
[IMG]local://upfiles/6892/ACD99162AAD640DD8E012A84402ED505.jpg[/IMG]
ibified
Aug 18, 2012 08:48 AM
DONT DO IT
Jun 15, 2011 03:37 PM
New Daddy
Jun 7, 2010 10:27 PM
HRH
Sep 10, 2009 09:23 AM
Nicholunch
Oct 9, 2005 01:12 AM
