96 850 ABS Module
Old Oct 3, 2009 | 03:15 PM
beecho's Avatar
Lightbulb 96 850 ABS Module
Can anyone tell me where the ABS/Traction module is located. My light came on and I saw on here that it is possible to clean it and maybe it would need resoldering job. Don't know if it is possible but willing to try to save money from Volvo. Any suggestion are welcome. Thanks!!!!
Old Oct 3, 2009 | 05:24 PM
blackbrick's Avatar
This link may help you http://www.bba-reman.com/content.asp...uctions_repair
Old Oct 3, 2009 | 06:35 PM
beecho's Avatar
thanks blackbrick that site was great!!!!
Old Oct 3, 2009 | 08:26 PM
JPN's Avatar
JPN
Another alternative:
http://home.earthlink.net/~vicrocha/
Good luck,
JPN
Old Oct 3, 2009 | 10:26 PM
confused_al's Avatar
If you are not afraid to try, here is Ozark Lee's wonderful write-up:
http://www.matthewsvolvosite.com/for...?p=46827#46827
Old Oct 4, 2009 | 12:46 AM
jnduke's Avatar
I just got mine back from the guy that JPN provided the link to. It looks great but haven't started the car up yet, so not sure I can fully endorse him yet. The price is good- but it took over two weeks, and I have not hooked up the battery cable since I removed. Either way you go you'll need an E5 tork socket and that is not easy to find. I got mine from IPD. Go ahead and order one because you can't do anything without it. The site JPN sent you has great info and instructions on removing.
Old Oct 4, 2009 | 09:33 AM
JPN's Avatar
JPN
For those who're stuck with '93-'95 modules:
https://volvoforums.com/forum/volvo-850-16/abs-controller-cover-removal-11104/
Good luck,
JPN
Old Oct 4, 2009 | 09:39 AM
https://volvoforums.com/forum/showthread.php?t=11104
Good luck,
JPN
That link is for the newer modules.
Hopefully soon I will be able to do one for the older ones. As I have to pull mine apart and fix it
Old Oct 4, 2009 | 09:51 AM
JPN's Avatar
JPN
Tech, I.....
SUCKED!
But babies suck more than I do.
JPN
Old Oct 4, 2009 | 10:24 AM
It's ok we can all be wrong once in a while!!! I am wrong all the time as well!!
Old Oct 4, 2009 | 10:32 AM
JPN's Avatar
JPN
Thank you for that.
JPN
Old Oct 4, 2009 | 02:11 PM
beecho's Avatar
Talking
Thanks everyone for all your advice. Looks like I will have to send mine out to be fixed.
Old Oct 7, 2009 | 04:38 PM
jnduke's Avatar
I installed my rebuilt ABS module- that Victor Rocha did. Works just fine. It came wrapped up in one of those fancy bags like new computer harware comed in- you know the grey shiney anti-static stuff. I think it felt heavier (always good for a Volvo) but that may just because I hadn't held it in a while. Works great- no ABS light, system works- what else do you want for $140 dollars, plus an E5 socket and 10mins of time? I would reccomend his rebuilding service.
Old Oct 7, 2009 | 06:42 PM
s_moneh's Avatar
where can i grab new screws for the module as they r old/corroded/stripped?
Old Oct 8, 2009 | 12:24 AM
boxpin's Avatar
fyi...I have an ABS module too.
Old Oct 8, 2009 | 01:55 AM
JPN's Avatar
JPN
Agreed
It may have felt heavier, because the Vicrocha guy not only fixed the module but also upgrades them for more reliable performance. I can assume he may have installed heat sink or anti-vibration gadgets. You can call him to see if he added something that made the module heavier.
As to the screw question, if you cannot locate the same one at an auto parts shop, hardware shop or junkyard, you can bite the bullet and go to the dealer. They may charge $10 for the screw to screw you, but they may only charge $3 for it.
Good luck,
JPN
Pej
Nov 17, 2010 01:07 AM
Rosew6211
Aug 5, 2010 11:53 PM
volvoexpert
Jul 14, 2009 02:45 PM
EATMAN
Jan 29, 2009 12:50 PM
EATMAN
Jan 4, 2009 10:54 AM
