96-850 MAF sensor.
Old Nov 29, 2010 | 10:37 AM
Rosew6211's Avatar
Default 96-850 MAF sensor.
After recent gas fill, car began to bog down and die. Changed fuel filter, checked fuel rail pressure-OK. OBD 11 code read MAF weak circuit. Cleaned MAF sensor with sensor cleaner. All to no avail. Car would run short while OK, then sputter dpwn and die. Couild keep motor running for while longer by pumping accelerator and keep RPM above 2,000; however sooner or later, say 2 minutes, it would die. Finally, I just disconnected MAF Sensor electrrically. Now motor runs almost normal, slight hesitation at times at low RPM.s. Help! Does this mean MAF Sensor is bad? Am hesitant to put out cost of new sensor only to find it is not the problem. Thanks all for any help you can give.
Old Nov 29, 2010 | 01:49 PM
boxpin's Avatar
Do you have a wrecker or a friend that owns a 850 that would let you swap the part?
Old Nov 30, 2010 | 08:36 AM
Rosew6211's Avatar
Great ide. Thanks. My wife has a 2004 XC 70 cross country. Perhaps I should try it. OK?
aleksey17
Dec 29, 2011 12:54 AM
aleksey17
Dec 23, 2011 11:33 AM
white83glt
Sep 5, 2010 11:07 PM
02VolvoS40
Jul 16, 2010 08:12 PM
Mr Zed
Aug 12, 2005 01:18 AM
