'96 850 starting problem?
Old Dec 20, 2005 | 06:28 PM
hordezla's Avatar
Default '96 850 starting problem?
hey guys!
I have '96 volvo 850, 2.4 non-turbo. It just started giving me problems on start-up. It takes about 6,7 seconds before it turns over and then once it starts it's shaking for the first few seconds, from there on it is all fine. Runs great, no CEL, no codes, everything seems fine.
I replaced battery, plugs, wires, cap and rotor, and I still have the same problem. It actually never left me stranded, it always starts after few seconds but I am afraid this is not going to last forever and I want to get it fixed. Any ideas, tips?
Old Dec 20, 2005 | 07:19 PM
rp850's Avatar
Default RE: '96 850 starting problem?
Leaky fuel injector?
Old Dec 20, 2005 | 09:22 PM
Somehow you need to check and monitor the fuel pressure.
Old Dec 21, 2005 | 12:40 AM
hordezla's Avatar
what is the best way to do that?
Old Dec 21, 2005 | 12:52 AM
Get a fuel pressure Guage and it will screw onto the end of the fuelrail. See if the fuel pressure drops to Zero acter sitting. If it does then the fuel pump is bad.
Old Dec 26, 2005 | 05:13 PM
hordezla's Avatar
thanks tech!
Does this car have a cold start switch maybe? Reason I am asking is because it always starts fine after it's warmed up, only problems occur when it's been left sitting for a while.
Old Dec 27, 2005 | 02:51 AM
No it doesn't have a cold start switch.
Also keep an eye on the coolant temp sensor.
Old Dec 27, 2005 | 03:27 PM
hordezla's Avatar
fuel pressure is fine and I replaced coolant temp. sensor today, nothing changed[:'(]
Old Dec 28, 2005 | 01:18 AM
Still sounds like a fuel delivery problem.
fig
Jan 26, 2010 10:00 AM
Dennis C
Nov 19, 2009 08:16 AM
1960galaxy
Jul 10, 2009 01:25 PM
gbdunn
Aug 11, 2006 12:10 AM
