96 850T - No longer runs - help please!
Old Sep 23, 2008 | 10:41 PM
jbrubaker001's Avatar
Default 96 850T - No longer runs - help please!
Ok, here are the facts:
- 96 850 GLT - 146k miles - up until a few days ago the car ran fine
- Loaned car to sister in law who ran the car out of gas (I believe) - added gas and car ran again to the gas station
- filled car up w/ premium and a fuel injector cleaner but car would not start and hasn't since
- starter does runbut car will not turn over
- this may or may not be related but the idle air control valve is humming and won't stop
What does everyone think and what do I need to do to get this thing running again?
Old Sep 24, 2008 | 02:37 AM
RedTurbo850's Avatar
Default RE: 96 850T - No longer runs - help please!
Fuel pump priming?
Old Sep 24, 2008 | 07:48 AM
I do not hear any activity from the fuel pump area w/ the key in the start position. I know this may be the fuel pump but would the fp go from working fine to dead w/o any symptoms?
Old Sep 24, 2008 | 08:29 AM
Psaboic's Avatar
It is possible. Another thing to check is to see if running the tank dry sucked up a lot of crud into the fuel filter. It may be clogged
Old Sep 24, 2008 | 06:37 PM
The pump will not stay running all the time with the key on. When you turn the key on it only activates for a few seconds then kicks on when the car is cranked.
Old Sep 24, 2008 | 07:46 PM
I was already going to replace the fuel filter this weekend. I am hoping this was the problem when running low on fuel. Does anyone konw of any easy diagnostic checks to determine if the relay or pump is bad?
Also, does anyone have any thoughts on the idle air control valve humming all of the time?
Old Sep 24, 2008 | 08:18 PM
The idle motor will hum some. That is normal.
Check for power at the pump first. Or just remove the relay and open it and check for bad solder joints.
Old Sep 26, 2008 | 01:09 PM
I've checked the relay and everything looks good. At the same time, my battery is dead and I'm sure it has to do w/ the "humming" idle air control. I dont' remember this thing running non-stop prior to this problem.
Who knows?
Old Sep 26, 2008 | 07:53 PM
It shouldn't hum with the key off though.
Old Oct 4, 2008 | 11:13 PM
I know it should not hum w/ the keys out. Does anyone know what might cause this and a potential method to fix?
Old Oct 4, 2008 | 11:19 PM
Maybe try removing the ECM module and installing it and see if it makes a difference.
Old Oct 11, 2008 | 09:28 PM
Ok, I haven't removed and reinstalled the ECM yet but I have replaced the fuel pump relay, fuel pump and filter and.......the damn thing still doesn't run nor is there any indication that it will run. I am at a loss. Any last ditch ideas before I remove the ECM/take this car to a shop?
Old Oct 12, 2008 | 06:14 AM
The ECU takes 2 minutes to slide out and clean and install.
Also I assume you have fuel,spark, and injector pulse?
Old Oct 16, 2008 | 01:09 PM
OK - I pulled out the ECM and replaced - no change. I then took at multi-tester to see if I was getting any juice to the fuel pump - it does not appear that I have any power at the pump. I simply plugged the multi-tester into the red connector which connects to the fuel pump.
Any thoughts?
Old Oct 16, 2008 | 01:13 PM
Under the hood in the fuse panel is a relay for the fuel pump.You will have to remove the 4 t-25 screws to get to the relay. The relay might be bad. You can remove the relay and inspect the solder joints.
Old Oct 16, 2008 | 09:02 PM
Already replaced the relay. I really do need help. Will you plesae review this thread from the beginning and let me know what you think?
Old Oct 16, 2008 | 09:57 PM
  #17
Let me look in the morning and try to figure it out. Tried to pull up my wiring diagram and the computer is acting up and cannot open the diagram I will fix in the morning and post back.
Old Oct 29, 2008 | 02:55 PM
  #18
Ok, finally had to take the car to my local shop. They checked it out and ended up replacing the fuel injector relay. This fixed all problems - $168 w/ relay.
Thanks to all who tried to help.
Old Oct 29, 2008 | 04:04 PM
  #19
Sorry I could not help more.
drizzt05
Oct 7, 2007 07:34 PM
VolvoDriver
Feb 17, 2007 02:35 AM
gbdunn
Sep 14, 2006 05:46 PM
tupapison
Jul 29, 2006 12:29 AM
becbam
Aug 30, 2005 02:28 AM
