97- 850 speedo, odom, cruise not working
Old Nov 29, 2010 | 04:23 PM
dallasmenard's Avatar
Default 97- 850 speedo, odom, cruise not working
I have a 97 850 that has an intermittent problem with the speedometer, odometer and cruise control. When they work they all work perfectly, but with no rime or reason they all stop working together, maybe for 10 minutes, maybe for 10 days.
Any one else experience anything like this
Old Nov 29, 2010 | 04:40 PM
kockyhardrockr's Avatar
Sounds like fuse/relay/wiring is loose/bad connection/faulty.
Check your fuses, and replace the one for that circuit even if it looks ok. I've had ****ty fuses trick me before.
Then I'd say you might need to get behind the dash to check the connection isn't loose there. I don't know anything about circuits, but i get by. It works or it doesn't
rspi
May 15, 2014 07:36 AM
bbiljah
Aug 20, 2013 11:26 AM
Reefers4U
Jun 22, 2013 11:07 AM
cgreygoose
Jan 5, 2013 10:04 PM
pumahitman
Oct 14, 2010 04:21 PM
