97' 850 T5 speedometer intermittant
Old Jun 24, 2014 | 07:36 PM
gearhead's Avatar
Default 97' 850 T5 speedometer intermittant
I have an issue with my speedometer that I believe is a relay problem but the wiring diagrams I have are not very good. The speedometer works most of the time in cold weather but after a good heat soak or in hot weather it will go to zero and stay. It is an intermittant problem but is much more prevelent in warm weather. All other instrument panel functions are normal. The cruise control works fine except when the speedo is not working which I believe is normal.
Any ideas would be helpful.
Thank you,
gearhead
Old Jun 26, 2014 | 06:47 PM
Hi and welcome to the forum.
Do you have a ABS light?
Old Jun 28, 2014 | 12:03 AM
gearhead's Avatar
Yes I have an ABS light on. Have just purchased the torx socket to get the box off and repair the solder joints (if that turns out to be the problem)
So is there a corrolation with the abs and the speedometer?
Old Jun 28, 2014 | 08:27 AM
Yep.....
Old Jun 28, 2014 | 10:53 PM
gearhead's Avatar
Thanks.
Old Jul 7, 2014 | 07:59 PM
cablejohn45's Avatar
Had (past tense) the same problem (intermittent speedo- mostly interNOTworking) unplugged the connectors on the ABS and squirted some marine grade electronic oil in the ends of the connectors-soaked them good, plugged them back up, Speedo started working. My ABS light has never been on but might be a burnt out bulb.
Old Jul 7, 2014 | 08:32 PM
If you turn the key from OFF to RUN without starting the car, you will know if the bulb is out.
Matthew Ruvalcaba
Mar 16, 2014 02:57 AM
sbrownbw
May 3, 2013 08:09 PM
Psaboic
Nov 6, 2007 10:26 PM
jg38141
Oct 25, 2007 11:18 PM
Psaboic
Mar 11, 2007 01:59 PM
