97 850 wont start ran fine yesterday
Old May 5, 2012 | 11:11 AM
Elizabeth Shepherd's Avatar
Default 97 850 wont start ran fine yesterday
Went to start my car this morning but it wouldnt. It will not start. Tested the battery and its good. We already know the car throws codes for the number three spark plug. The ignigtion(?) coil not responding to voltage test.
Any suggestions?
Old May 5, 2012 | 11:15 AM
Hi Elizabeth, welcome to the site.
If you have a problem with the ignition coil I would start there.
There are several things you can check starting with fuel pressure. Can you hear if the fuel pump is running in the back seat area when it fails to start?
Are you getting spark? Fuel? Air? Is your timing belt still connected?
Old May 5, 2012 | 12:07 PM
fuel pump not working! URGH! They said that there two different kinds for this car any ideas what kind it is?
Old May 5, 2012 | 02:05 PM
Who told you that? Could be the relay. Take it out and put it back in and see if that helps.
Jerry Balch
1998-2000 model year XC70
Feb 15, 2014 11:51 PM
Volvomotoringdutchman
Dec 29, 2012 03:08 PM
furball3
Jan 28, 2007 03:31 AM
chrismears
Feb 19, 2006 11:38 AM
