ABS light
Old Dec 20, 2009 | 03:06 PM
Bobec's Avatar
Default ABS light
I've had an intermittent ABS light that is temperature related. I thought when I did my brake job that cleaning the sensors might help but it didn't. On cool or cold mornings I get no light even after driving long distance but on warm or hot afternoons it comes on quickly.
Any ideas?? Thanks
Old Dec 21, 2009 | 10:11 AM
fcpgroton's Avatar
Former Sponsor
Most of the ABS issue with the 96 850 is because of the ABS control unit. The solder joints seem to wear out and it causes the ABS not to work.
Old Dec 21, 2009 | 10:43 AM
frustrator-bolt's Avatar
Have you checeked to see if you are getting any OBD codes associated with the ABS system. I had a fault code that showed a faulty break pedal position sensor which lite up the ABS light on the instrument panel.
Old Dec 21, 2009 | 12:50 PM
Bobec's Avatar
Thanks for all the input. While browsing the V70 area I came across some useful info posted by Howardc64, his website has some very useful stuff
http://howardsvolvos.webs.com/driveline.htm
and a link he had to here
http://home.earthlink.net/~vicrocha/
It had more info on the ABS control module. apparently the problem is known for being heat related. When I get a chance I'll take my module off and take it apart to see what components can be upgraded or heat sinked.
Old Dec 21, 2009 | 08:25 PM
Scott Baret's Avatar
The vast majority of ABS lights are caused by faulty computers. I believe the solder is what goes bad on them. There are several places that will repair it for you (at a cost of roughly $100 and change) plus I think there are directions online if you're into DIY repair.
Whatever you do, don't take it to the dealer. They will want $800+ for a new computer when yours, in all likelihood, can be refurbished with minimal effort and funds.
I recommend Module Master (located in Idaho) if you want to send it somewhere to get repaired. The turnaround time was fast and the work was guaranteed for five years.
Old Dec 21, 2009 | 10:22 PM
I do alot of them at work. I atleast double the amount of solder on it than there was from the factory. I have never had one come back as of yet. The wifes is going on about 2 years now.
nealeas
Mar 24, 2018 09:59 AM
Scott V
2001-2013 model year V70
Feb 8, 2014 06:46 PM
piv15
Nov 3, 2012 07:56 PM
paulh
Jan 30, 2008 08:22 PM
robohopar
Sep 27, 2007 11:37 AM
