ABS+Tracs lights come on sometimes...?
Old May 7, 2010 | 06:02 PM
sbanks's Avatar
Default ABS+Tracs lights come on sometimes...?
Hey techs!
I need help, I have a 96 850 Turbo Wagon and about every third start I have this problem.
I'll start the car and the ABS light, along with the Tracs light will stay on... the Shift Lockout won't unlock with the brake depressed, and the dash/ODO/mpg readout, head lights and turn signals won't work at all.
Then, if I shut the car off, and try again, the problem goes away and everything works like it should. Sometimes it takes two tries, but always goes away. There are no codes to be pulled either.
Got any ideas? Can this be caused by a bad shift lock microswitch, or is this an ignition problem? Dash cluster problem? Anyone ever had this issue before?
Thanks in advance...
Old May 7, 2010 | 10:26 PM
I would start with the electrical part of the ignition switch. You might also have a bad ABS module.
Old May 21, 2010 | 09:47 AM
sbanks's Avatar
Default Fixed
Thanks- after a little more research, I decided to replace the electrical portion of the ignition. Works great now, problem solved.
Thank you
hunterw0026
Mar 21, 2011 09:49 AM
hjloap
May 19, 2010 11:55 PM
850R Dave
Dec 16, 2009 09:41 AM
850GLE
Sep 22, 2009 10:28 AM
paulh
Jan 30, 2008 08:22 PM
