AC codes...need some help
Old May 2, 2007 | 07:55 PM
J Taylor's Avatar
Default AC codes...need some help
Lately on my 94 850 turbo wagon the AC lights will flash for a bit after the car has been running with the AC on forminute or so. After they flash the recirculate will no longer work. These are the codes I am pulling on B1:
1-3-5 No Engine Temp. Frequency Signal
3-2-5 Recirculation Damper Motor Active Too Long
4-1-1 Pass. Compartment Fan Overcurrent Or Seized Fan
4-1-7 Pass. Side Temp. Sensor Intake Fan Seized
4-1-8 No Control Signal To ECC Power Stage
4-1-9 ECC Power Stage Emitting Faulty Diagnostic Signal
I cleaned the Pass side fan up by the oh-**** handle and thefan is turning fine (not sure if it was before or not, but it was pretty dirty).
Can anyone put this in english so I can figure out what the problem is?
Thanks!
JT
Old May 6, 2007 | 03:35 PM
J Taylor's Avatar
Default RE: AC codes...need some help
Anyone???
Old May 6, 2007 | 06:59 PM
RedTurbo850's Avatar
Try VolvoSpeed.com.
I honestly have no clue. Or perhaps buy a manual which can tell you what the codes mean..
Old May 7, 2007 | 10:11 AM
axelm's Avatar
http://www.matthewsvolvosite.com/dow.../Volvo_850.zip
Get that file and check out the A/C troubleshooting guide.
Regards
Lansdowne
Sep 22, 2014 01:02 AM
jderosa3
Mar 20, 2011 03:01 PM
B1mmer
Dec 18, 2006 11:24 PM
mattyremf
Aug 30, 2005 09:36 PM
