AC and Evaporator Question
Old Jul 18, 2005 | 12:41 PM
jcmartin's Avatar
Default AC and Evaporator Question
AC runs cold for ten minutes then air gets warm and humid. About the same time the AC problem started my son noticed that there was a small fluid leak from under the glove compartment. (I haven't seen it to figure out if it's water or something else)
Are the two related?
Does putting in more freon usually fix the warm air problem?
Thanks,
JM
Old Jul 21, 2005 | 11:11 PM
Default RE: AC and Evaporator Question
The compressor clutch might be bad.
Does it go back to being cold after a while?
Old Jul 23, 2005 | 02:32 PM
hordezla's Avatar
I didnt see any fluid leak on mine but I think I have the same problem, leaking seal on the evaporator or even evaporator itself. Every time I add more freon it blows cold for about 10 minutes and it goes warm. I added dye this time and few minutes later underneath the car water/condense came out green, so there is a leak on the evaporator somewhere. How hard it is to get to it tech? It's on the passenger side right? Can you give me some idea how long does it take? thanks!
Old Jul 23, 2005 | 05:45 PM
I have done a bunch of them and I can have it done in about 3 to 4 hours.
Book time is 10 hours.
Check out my instructions in the 850 section.
Old Jul 29, 2005 | 03:45 PM
fast850r's Avatar
Default RE: AC Question
I've noticed my A/C will start to get cold. After a few miutes of cold air, it starts to warm up and blow warmer/humid air. Then it goes back to blowing cold. Kind of comes and goes. Any thoughts?
Old Jul 29, 2005 | 09:22 PM
ORIGINAL: fast850r
You might be low on freon.Then the system is cycling due to low pressure.
Old Jul 30, 2005 | 06:30 PM
fast850r's Avatar
Thanks Tech. Now, where do I find the A/C connections? I have 134a in the garage, but don't see the fittings like in my other cars.
Old Jul 30, 2005 | 06:48 PM
The connection is under the hood on the right side of the car buy the engine and trans computer.It will have a black cap on it will yellow or white writing on it.The writing on it is the torque spec for the cap.
Old Aug 1, 2005 | 10:54 AM
jcmartin's Avatar
By right side, I'm assuming that you are referring to the passenger side. Is that connector the low side of the compressor? Does anyone have any pictures of the location?
Thanks,
JM
Old Aug 1, 2005 | 11:37 AM
fast850r's Avatar
Yeah. any pics? I have a turbo if that makes a difference. On top of the passenger side strut tower, I have a yellow sticker saying it uses 134A and should be serviced by a professional. I have 134a in my garage that I can use, just need to know where fitting is to top off.
Old Aug 9, 2005 | 09:03 AM
fast850r's Avatar
OK. I found the fitting, down next to computer box. Gave a little shot of 134a, and yea!!
I have cold a/c again.
iappo
Apr 2, 2015 10:21 PM
laytonco
May 25, 2011 01:23 PM
jmana
Sep 6, 2007 05:11 PM
jfikentscher
Oct 28, 2005 09:28 PM
Jadams1
Aug 16, 2005 12:42 AM
