AC/Heater Blower won't work when car is running
Old May 2, 2010 | 01:19 PM
SteveRep's Avatar
Default AC/Heater Blower won't work when car is running
850 GLT: When I turn the key to the accessory position, the blower comes on and runs on high, regardless of the switch position; however, when I turn the car on, within 2-3 seconds, the blower quits. Is there a relay overloading somewhere?
Thanks!
Last edited by SteveRep; May 2, 2010 at 01:41 PM. Reason: left off year, make, model and the fact that though the blower runs only on the acc. position, the switch is inop
Old May 2, 2010 | 03:28 PM
Turconator's Avatar
I'm thinking resistor for this one.
Old May 2, 2010 | 06:13 PM
SteveRep's Avatar
A mechanice who was quick to point out he wasn't that familiar with Volvo's told me he thought it was the blower motor. But since the blower motor does run and does so smoothly, what you are saying about the resistor - is it a part of the blower motor or is it separate?
Old May 2, 2010 | 07:42 PM
boxpin's Avatar
+1 sort of a common problem.
The resistor is right to the left of the blower motor and can be picked up from HERE.
Please double check your year and whether you have climate control or not.
Old May 2, 2010 | 10:03 PM
SteveRep's Avatar
Thumbs up
Thank you very much for the help, Turconator and Boxpin. I'll pull the blower motor and see which resistor is nearby and order it up!
fiey24
Mar 30, 2015 10:53 AM
ibified
Sep 12, 2012 12:24 AM
function
Apr 1, 2011 11:34 PM
L740GLE
Jan 14, 2011 02:11 PM
lrorld
Nov 12, 2009 05:17 PM
