Flashers work when car is off but not when it is running
Old Mar 23, 2011 | 08:18 PM
function's Avatar
Default Flashers work when car is off but not when it is running
Worked fine this morning, but when I turned the car on this afternoon, flashers don't work when the engine is running (no clicking, nothing), but when key is in on position with engine off, flashers work fine. Hazards work either way. I guess that means relay is good - where to look next?
Probably coincidence, but also today shifter won't come out of park without pressing override, and ABS light goes out after a few seconds when key in ignition, but as soon as engine is turned on ABS light goes on and stays on. It is the first warm day today, car was warm inside. I guess the gremlins came out of hibernation.
The car is 1995 850 Turbo Sedan.
Old Mar 23, 2011 | 08:28 PM
Sounds like your ignition is going bad. Did the windows work? Try starting the car and turning the key back just a little. I have had several 960's that do this. My current 960 had an ignition that doesn't spring back the way it should.
Old Mar 23, 2011 | 09:22 PM
function's Avatar
You are absolutely right... helping the key back fixes the problem with flashers, ABS light and shifter. Do you know what part needs to be replaced, or if squirting in appropriate lubricant is likely to help?
Old Mar 23, 2011 | 09:26 PM
The electrical part of the ignition switch needs to be replaced.
Old Mar 23, 2011 | 09:28 PM
1993-1997 Volvo 850 Ignition Switch | Volvo 850 Parts
Old Mar 23, 2011 | 10:40 PM
Is that the same problem on my 960? Are you saying that it IS springing back far enough and that the internal part of the connections are bad?
I just turn the key back and keep going. Been doing that for years now.
Old Mar 26, 2011 | 07:58 AM
Yes you need a new electrical part of the ignition switch.
Old Apr 1, 2011 | 11:34 PM
function's Avatar
Thanks for great advice. Part ordered, arrived and installed in 10 minutes. Works fine now.
damnitkage
Jul 19, 2011 10:54 AM
enoble
May 29, 2010 03:51 AM
ricky
Oct 22, 2009 03:20 PM
volvro18
Oct 13, 2008 07:57 AM
Volvos since 1964
Feb 7, 2005 10:55 AM
