Air Bag Light On...
Old Nov 17, 2013 | 07:05 AM
Talesin's Avatar
Default Air Bag Light On...
Air bag light on, apparently common fault with dirty contacts on multiplug under drivers seat advise/help please to clean or deal with asap!
Old Nov 17, 2013 | 02:21 PM
SRS light being on is NOT common. What model car do you have? At any rate, you will need to take the car to a professional to have the SRS light dealt with.
Old Nov 17, 2013 | 03:15 PM
What year, model car ?? If '95 or earlier 850 you can use the under hood diagnostic panel to at least find out what in the system has tripped the light.
The SRS light is not common.
Old Nov 18, 2013 | 04:55 AM
Talesin's Avatar
It is an 850 auto estate GLT 93/94 model. I am assuming this is an American site by your terminology of 'under hood'?! I was advised of this being a 'common fault with his model' by a Volvo specialist garage that has been in business for over 40 years and who I was a customer for 25 years! Perhaps our vehicles are a slightly different spec than for the American market?
Old Nov 18, 2013 | 08:43 AM
Brick850's Avatar
Being a 93-94 it will be OBD I.
The diagnostic unit is under the bonnet near the windscreen washer fill point.
Ignition off.
Remove the covers. Place the probe (wire with a bullet terminal on it) into socket B5.
Ignition to on, but don't start the car.
Press the button once next to the red LED.
LED will flash a three digit code. EG code 1-2-2 will be one flash, pause, two flashes, pause, two flashes.
Write the code down, then push the button once again to read any remaining codes. If it flashes the first code again that is all the codes there are.
Post up here or search for the code displayed and we can help narrow down what the error is.
Old Nov 18, 2013 | 08:49 AM
Old Nov 18, 2013 | 05:14 PM
You can save some money if you read your own codes. You could also try to reset it. If it's a hard fault it will just pop back on but if it was something intermittent you might get lucky and the light will stay off.
Snag a copy of the factory service manual from here:
http://www.matthewsvolvosite.com/downlo ... vo_850.zip
Once you unzip it see the file named air bag restrain system.pdf.
It will walk you through the procedure to test and reset the system, if you get any error codes it will also walk you through test procedures.
Don't use an Ohmmeter to try to test any of the airbags as it can actually trigger them.
Post your codes and we go from there.
Old Nov 18, 2013 | 08:59 PM
gdog's Avatar
A little googling and here you go:
http://www.volvoclub.org.uk/tech/ser...aintSystem.pdf
see pg 20, 21.
After MY 95, then it's a trip to the dealer and BO..
Old Nov 19, 2013 | 03:22 AM
Talesin's Avatar
To all who have replied to my present dilemma A very big THANK YOU! Unfortunately before I received this message car refused to start, [believe it to be the starter sensor relay as she turns over and the battery is healthy] So the garage was summoned and she is awaiting collection! I will however pass your comments on to the mechanical engineer, again many thanks for your help, it is much appreciated.
volvo_s70
Mar 9, 2013 11:54 AM
ScottyP5947
Feb 22, 2008 09:53 PM
GSP974
Jan 25, 2008 06:48 PM
PWHV07
Oct 4, 2007 12:15 AM
casper98gt
Oct 10, 2006 10:02 PM
