Air Conditioning disconnect
Is there a way to stop the compressor from kicking in when I turn on the defroster? My AC isn't working correctly (leaking somewhere) and I would like to use the defroster when the call arises without the compressor cycling all the time. I know I should just fix it, but I need to put money into other things for the next 6 or 7 months.
ORIGINAL: tech
Are you still using the A/C?
If not just unplug the A/C compressor and leave it unplugged.
Agreed that would be the Low pressure switch. But it might make the lights on the dash flash all the time.
The Compressor has a single wire that mounts on the side of the compressor in a white plug. Looking at it it faces the Radiator.
sabin333
Nov 2, 2014 09:11 AM
ac, air, airconditioner, conditioner, disconnect, disconnected, disconnects, forums, uf, volvo, wire
