Air Filters
Old Mar 20, 2007 | 11:14 AM
kakins's Avatar
Default Air Filters
Hello all my brick loversa couple of ?'s about air filters.
What kind should I buy for the Brick R?
Is it easily replaced?
Most important of them all what will a new air filter do for my baby?
If I'm replacing the filter should I replace anything else.
Old Mar 20, 2007 | 11:26 AM
S70driver's Avatar
Default RE: Air Filters
Either get an OEM paper filter or a K&N panel filter. Very easy to install.
Old Mar 20, 2007 | 12:53 PM
axelm's Avatar
OEM Mann Filterpart numberC 35 148
To replace, open the hood, go to air filter box on the left side of the car (says TURBO on my T5). Open the filter box by snapping clips off with your hand. Removethe old filter and install the new one. Make sure the new filter is correctly fit otherwise dirt can get into your engine. Snap the clips on and your ready to go. It shouldn´t take more than a minute and no tools are necessary..
Old Mar 20, 2007 | 02:53 PM
JimKW's Avatar
I would allow at least two minutes. Some of those clips are hard to find and very hard to push back on, but less than three minutes totat for sure. I just bought the Mann filters from fcpgroton along with 10 Mann oil filters. I took out the K&N that came with my 97 850 R bacause I read some stuff I didn't like about it, and I was not good about keeping it oiled just right.
Old Mar 20, 2007 | 04:37 PM
kakins's Avatar
So should I order this item from like sweedspeed or can I pick up from local store?
Old Mar 20, 2007 | 05:20 PM
axelm's Avatar
I buy them at the store where I change my oil, but I suppose you could buy them at www.fcpgroton.com or even on ebay. They are not difficult to find. You could also do the same thing Jim did and also get 10 Mann oil filters to make the S&H worthwhile.
Old Mar 21, 2007 | 12:01 PM
JimKW's Avatar
The Mann oild filters were $3.90 each or 10 for $35.00 which comes to only $3.50 each at fcpgroten. Since I own three Volvo's that all use the same filters, buying 10 makes sense.
Old Mar 22, 2007 | 02:10 PM
white out's Avatar
I picked my K&N up from autozone.
Nick
Old Mar 22, 2007 | 04:40 PM
axelm's Avatar
ORIGINAL: JimKW
If you only have 1 Volvo, those ten filters will last you 50 000 miles. It's good to take your own filter when you change the oil because sometimes they don't have the correct one and they use a similar one without the valve that the Mann oil filter has.
Old Mar 22, 2007 | 05:50 PM
JPN's Avatar
JPN
I myself change it at every 1 year/10,000 miles. Hey, they are cheap.
Cleaner filter allows smoother air flow and saves fuel a bit. Also, excessively dirty filter causes starting problems. You can clean the air filter with a vacuum cleaner, as long as the filter is "dry" type. In Japanese market there are "wet" filters that has thin film of oil. They say wet-type filters catch particles better but dry type is sufficient and are easier to handle, as we-type filters cannot be cleaned.
Think of an engine like a vacuum cleaner. Filters for vacuum cleaners are a lot more expensive than automotive air filters[8D].
Good luck,
JPN
P.S: Dial-up sucks.
movistardave
Jan 20, 2013 12:07 PM
jholst
Jan 31, 2011 01:18 AM
Jonathan Logan
Oct 13, 2008 01:05 AM
bluemagicbus
Sep 10, 2008 08:22 AM
tom1568
Dec 21, 2005 01:13 AM
