Alternator
Old Aug 26, 2018 | 08:26 PM
Phil 850's Avatar
Default Alternator
I have been hearing a noise like a bad bearing for a while now and have traced it to a bad bearing in the alternator. The Haynes manual says unbolt the old one and lift it out then bolt in the new one. They don't say anything about all the stuff in the way. Any suggestions on this? Are there any write ups on it?
Old Aug 27, 2018 | 11:16 AM
firebirdparts's Avatar
If you take the cooling fan out (which is really easy), you might be able to get it out. The power steering pump is reasonably easy to remove if you need to. I hate working in that area of the car.
Old Aug 27, 2018 | 09:48 PM
Phil 850's Avatar
I started looking at the RSPI vidio and it doesn't look bad.
Old Sep 2, 2018 | 11:46 PM
Phil 850's Avatar
So I did this project today and if I did it a second time it would probably take no more than two hours but, and that's a big but. not being entirely sure of the bolt locations it took a lot longer. The bottom bolt of the power steering bracket was the worst. If you are going to do this make sure you check the location of that bottom bolt first as it will save you a lot of time.
AutoNaut
Aug 21, 2016 12:33 AM
Wesley brown
Apr 19, 2014 08:34 AM
arekaye
Mar 26, 2013 04:45 PM
donf
Dec 25, 2011 08:04 PM
TheRev240
Aug 6, 2008 11:02 PM
