Alternator Regulator Replacement-94 850
Old Nov 20, 2013 | 12:03 PM
97black850's Avatar
Default Alternator Regulator Replacement-94 850
Hey guys,
You're probably sick of alternator/ charging system questions, but how hard is it to replace the regulator on the alternator? I am a lil short on cash being in school and I found the Bosch replacement for about 35 on Eeuro. Any help is appreciated, thanks
Old Nov 20, 2013 | 04:04 PM
Not bad at all. Pull the alternator, remove the cover, 3 screws, then pull the regulator, 2 screws I believe.
Are you sure your alternator is bad? These cars have bad cables which effect the charging. A guy on Matt's site just did a fix that is working very well for him so far. He removed the battery and soldered the connector and his system is now charging at 13.89 v.
Old Nov 20, 2013 | 10:44 PM
97black850's Avatar
hmm, i will try that actually and return the part if it works. someone mentioned doing the regulator without removing the alternator but i don't see how that is possible
Old Nov 22, 2013 | 08:48 PM
gdog's Avatar
Don't know anyone who would let you return electrical parts after they've been installed.
Old Nov 22, 2013 | 11:59 PM
Chrispy_T's Avatar
He meant fixing the cables. If the cables are the problem then he will return the part he wouldn't need.
Old Nov 23, 2013 | 08:54 AM
97black850's Avatar
yea ill try the cables first and see if it helps
Old Nov 23, 2013 | 05:05 PM
97black850's Avatar
regulator did the trick! all done with alternator in car
Old Nov 23, 2013 | 09:44 PM
Very nice.
artemis_f0wl
Apr 30, 2009 06:58 PM
Business_Socks
Feb 2, 2009 05:50 PM
ibcmoore
Dec 6, 2008 12:20 PM
deftonedworld
Dec 11, 2007 10:14 PM
kman3786osu
Oct 20, 2006 11:25 AM
