annoying rattle
Old Jun 30, 2006 | 09:59 PM
855turbo95's Avatar
Default annoying rattle
There is a somewhat annoying rattle that seems to be coming from the DS a-pillar or that corner of the dashboard. I've tried to trace it, but have been unsuccessful. Is there anything in these cars that typically makes such a noise? Any shortcut that someone can offer would be great.
Thanks!
Old Jul 1, 2006 | 10:28 AM
Default RE: annoying rattle
2 Things in that area that are common are 1. The plastic peice that comes out of the A-pillar panel for holding tickets/other things. 2. The dash is common to break the mounting tabs.
Either Grab the dash on the drivers side and slightly push and pull and see if you hear the noise. Or drive and push in on the dash and see if the noise stops.
Old Oct 5, 2007 | 03:41 PM
quarterdimenickel's Avatar
I've got the same thing on both sides. Is there an easy fix?
EDIT: If I hit the top of the dash, it will either get worse or go away for a while. I'm pretty sure it's not the clip.
And while we're on the subject of rattles, the plastic trim piece on my passenger fender is loose, and I believe it's making a fairly obnoxious noise (but maybe it's the suspension?). Is there a way to secure it?
Old Oct 5, 2007 | 09:04 PM
mrpyromaniac's Avatar
I had the same problem on my 93 850. Believe it or not, the rattle was actually the speakers in the dash. They are held in with tabs that came loose and the speakers were actually rattling around when I hit bumps. The speaker covers pop right off with a flat blade.
They are held in by metal clips that can usually be bought at your local parts store. If it is the entire plastic skirting that is collapsing, you may have to rig it up using some extra big washers or something, as those can get ripped at the anchor points. Maybe it would help if you described the noise?
Old Oct 6, 2007 | 09:17 AM
ORIGINAL: quarterdimenickel
Sounds like the mountings on the dash broke.
The clips don't break the plasitc breaks.
Old Oct 6, 2007 | 03:10 PM
Well, it's more like a clunk than a rattle. I originally believed it was the suspension, but when I checked everything looked alright and I noticed that the trim piece was loose.
Old Oct 6, 2007 | 05:00 PM
Can you push and pull on the dash and feel it moving quite a bit?
Old Oct 8, 2007 | 05:25 PM
I can feel it shift a little, but it's not like it's a measurable distance.
I'll try pulling the speaker caps off tomorrow and hope that's the problem.
siarts
Apr 24, 2012 03:05 PM
Sambar Stag
Apr 20, 2010 11:49 PM
C70CoupeMaui
Nov 26, 2009 02:46 PM
jbroox
Apr 17, 2008 06:28 PM
gibbo
May 22, 2005 11:13 PM
