Another overboost post...
Old May 16, 2019 | 02:00 PM
shawneesnaketail's Avatar
Default Another overboost post...
Hello all. I drive a 95 turbo wagon. I have done the PCV, Timing overhaul, PS pump, fuel filter/injectors, cleaned throttle body/idle air/ trans drain, replaced turbo with 16T, all new silicone lines (correctly placed, and a had a high flow CAT put in). I am boosting consistently to 14 PSI with the waste gate adjusted super conservatively. The other day I hit fuel cut off and it scared the crap out of me. Boost does not start until 2300-2500 rpms, but spikes to 14 psi. I have tested the Bypass valve and it hold vacuum but the gauge will slowly go down... Is my wastegate flapper stuck closed, or not opening enough? I have tested the actuator and it moves at very little PSI. I am at a loss as I have tried 2 different TCVS.
95 turbo wagon, RIP kit, EGR, OBD I and II, LTRM fuel trim is roughly +3-4%, average engine temp 195, MPG 18-19 city.
PS, with my TCV unplugged I got 0 boost whatsoever.
Old May 17, 2019 | 05:01 PM
firebirdparts's Avatar
I drive a manual 1998, and I have a compound pressure gage, so it allows me to experiment some, which I did on the way to work this morning. I don't think what you are seeing there about boost coming on fast starting at 2300 rpm is out of line. That sounds reasonable. I can get boost below that, but your car would downshift in that situation. There is definitely not much pressure available below 2000.
dbraddock
Oct 15, 2015 01:59 PM
ENDEE666
Oct 12, 2012 08:51 PM
s_moneh
Mar 19, 2010 10:12 PM
fasteddie042
Jan 1, 2010 10:42 AM
blkwgnt5r
Mar 10, 2005 01:18 PM
