Ashtray bulb always on.
Old Feb 7, 2015 | 01:03 AM
Jeff Smyth's Avatar
Default Ashtray bulb always on.
Hello,
I recently bought a volvo 850 GLT '97 and noticed the rear ashtray bulb was dead. I installed a new one and it works but it's always on when the car is on. Is that how it should be?
Regards
Old Feb 9, 2015 | 07:35 PM
when you say stays on, do you mean when the key is on or when the car is off as well? do you use your headlights as daytime running lights?
Old Feb 10, 2015 | 02:36 AM
Jeff Smyth's Avatar
Only when the key is on. The bulb in the front ashtray is also dead so I can't see how that one works. The headlights are always on - due to swedish law.
Old Feb 13, 2015 | 01:09 PM
seems to me its tied into the interior/dash lighting and is lit because your headlight switch is in the on position. My 850 is away at school so I can't check to see if there is a micro-switch that toggles when the ashtray is open or closed. Simple fix is to put in the bad bulb again or leave as is.
Old Feb 14, 2015 | 07:33 AM
Jeff Smyth's Avatar
That is exactly what it is, thanks! Turning the lights off turn the ashtray bulb off. I don't mind having it on always, it was just the not knowing how it worked. Anyway thanks again!
Old Feb 14, 2015 | 05:44 PM
Originally Posted by Jeff Smyth
Hello,
Regards
Yes.
bond007
Jan 30, 2011 09:54 PM
crad159
Nov 23, 2008 09:02 PM
wv 850
Mar 27, 2008 02:30 PM
curtisckey
Feb 9, 2008 04:25 PM
almared6
May 19, 2007 06:28 PM
