Auto Shifter Question
Old Oct 24, 2005 | 12:16 PM
fast850r's Avatar
Default Auto Shifter Question
Is there a switch that can be adjusted at the shifter? Reason is, I have to pull back sometimes when car is in park, so it will start. Once I start driving, it just winds out and tach goes way up. If I just pull back and give a little pressure when in "D", it will downshift, and then shift normal, as long as I continue to apply pressure. Once it is warmed up, it seems to go away.
Old Oct 25, 2005 | 02:40 PM
info2x's Avatar
Default RE: Auto Shifter Question
sounds like the mechanical linkage between the shifter and the PNP switch has gone awry. It could just be that the PNP swich came out of alignment, if that's even possible.
Old Oct 26, 2005 | 12:08 AM
Sounds like either the PNP is worn or out of adjustment.
Old Oct 26, 2005 | 10:31 AM
fast850r's Avatar
Thanks for the replies. This all started when I had to have the rear main seal replaced, so of course they had to pull the tranny to do it. Since then, I have no back up lights, and this situation with the shifter.
Old Oct 26, 2005 | 08:50 PM
Take it back to them and complain.
xDread92x
Jul 21, 2019 04:18 PM
jasond011
Sep 13, 2010 04:02 PM
sandraqu
Dec 24, 2009 02:36 PM
Brently13
Sep 17, 2007 11:22 AM
danielribo
Jan 22, 2006 12:32 AM
